SMath Studio Forum
Extensions
EXCEL (2003+) I/O with recalculation and export to PNG
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,640   Was thanked: 1400 time(s) in 817 post(s)
Originally Posted by: Alex M.  What do I need to know so that I do not interfere with useful changes you have made? You can use Initialize() and GetTermsHandled() methods to add your features as before. If you add code and do not remove what is there, then there should be no problems. If problems arise, I will help to resolve them. Edited by user 16 November 2022 19:30:42(UTC)
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
Reading only 0s using excel_OUT()
For those in Canada, My Windows 10 had a "," separator that prevented the plug-in to read the data in Excel. The bug appeared when I decided to change the data format to numbers to have one decimal precision. It was showing only 0s. Changing the "," with a "." in the regional Windows setting was successful. Still showing "," in excel. Great plugin Thanks
Joined: 03/03/2014(UTC) Posts: 418  Was thanked: 127 time(s) in 96 post(s)
Originally Posted by: StephanB  Reading only 0s using excel_OUT()
For those in Canada, My Windows 10 had a "," separator that prevented the plug-in to read the data in Excel. The bug appeared when I decided to change the data format to numbers to have one decimal precision. It was showing only 0s. Changing the "," with a "." in the regional Windows setting was successful. Still showing "," in excel. Great plugin Thanks it's a known occurrence - I had difficulty incorporating regional settings into the plugin
SMath Studio Forum
Extensions
