4 Pages«<234
Offline uni
#61 Posted : 21 April 2023 21:17:35(UTC)
uni
Originally Posted by: ioncube Go to Quoted Post
How can I get properties of mixtures e.g
Code:
CoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]")
ref: http://www.coolprop.org/...properties/Mixtures.html
This can't be done directly in the current version of the plugin. It is not clear how to call the apply_simple_mixing_rule() function from the library, it can't be imported as it is not in the export table.
Click to enlarge
Click to enlarge
maple-python-coolprop.sm (7kb) downloaded 13 time(s).
maple-python-coolprop.pdf (20kb) downloaded 8 time(s).
Click to enlarge Crazy
maple-python-coolprop-2.sm (6kb) downloaded 8 time(s).
Edited by user 21 April 2023 21:56:13(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Razonar
#62 Posted : 22 April 2023 11:00:09(UTC)
Razonar
Uruguay
Code:
Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9.
On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version.
However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry.
Mixing gases.sm (20kb) downloaded 16 time(s).
Mixing gases.pdf (68kb) downloaded 17 time(s).
Offline uni
#63 Posted : 22 April 2023 11:34:44(UTC)
uni
More simple
Click to enlarge Click to enlarge Click to enlarge
maple-python-coolprop-3.sm (11kb) downloaded 13 time(s).
maple-python-coolprop-3.1.sm (11kb) downloaded 9 time(s).
maple-python-coolprop-3.2.sm (11kb) downloaded 12 time(s).
Edited by user 22 April 2023 14:13:24(UTC)  | Reason: Not specified
Russia ☭ forever
on 22/04/2023(UTC)
Offline uni
#64 Posted : 27 April 2023 09:09:34(UTC)
uni
Now you can write like this
maple-python-coolprop-3.3.sm (10kb) downloaded 12 time(s).
Edited by user 27 April 2023 12:29:10(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#65 Posted : 28 April 2023 13:39:13(UTC)
uni
Or like this
maple-python-coolprop-3.4.sm (11kb) downloaded 9 time(s).
maple-python-coolprop-3.5.sm (11kb) downloaded 12 time(s).
Edited by user 28 April 2023 13:58:45(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#66 Posted : 29 April 2023 21:33:10(UTC)
uni
Click to enlarge
maple-python-coolprop-3.6.sm (10kb) downloaded 18 time(s).
Russia ☭ forever
Offline churichuro
#67 Posted : 30 April 2023 04:07:03(UTC)
churichuro
Mexico
Was thanked: 27 time(s) in 22 post(s)
is fantastic!
this no work the first time but after I play with the another examples this work, very well
thank you!
Edited by user 30 April 2023 04:45:48(UTC)  | Reason: Not specified
Offline uni
#68 Posted : 04 May 2023 16:29:17(UTC)
uni
Without "pyfile" (inline multiline script). The script should be without comments.
Space padding is necessary here so that inside the script, when a large string is divided into parts, the line break character itself is not divided ( '\n' -> '\ n' ).
maple-python-coolprop-3.7.sm (10kb) downloaded 16 time(s).
maple-python-coolprop-3.8.sm (7kb) downloaded 13 time(s).
maple-python-coolprop-3.9.sm (9kb) downloaded 21 time(s).
Edited by user 04 May 2023 21:12:38(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ioncube
#69 Posted : 30 July 2023 14:12:32(UTC)
ioncube
Pakistan
Uni, can you please help me how to add python into SMATH, I have python already in system [WinPython 3.9] How I link it up with Smath?
I have working CoolProp
Offline ioncube
#70 Posted : 30 July 2023 19:33:42(UTC)
ioncube
Pakistan
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
Offline uni
#71 Posted : 31 July 2023 09:45:32(UTC)
uni
You should use a double slash for the full path.
In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly.
Edited by user 31 July 2023 09:49:17(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ioncube
#72 Posted : 03 August 2023 01:17:11(UTC)
ioncube
Pakistan
uni, thanks a lot
Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts]
Additionally Razonar sample here is also very intuitive while calculating mixing values
https://en.smath.com/for...-of-state.aspx#post82120
Edited by user 03 August 2023 01:19:12(UTC)  | Reason: Not specified
Offline uni
#73 Posted : 03 August 2023 09:06:16(UTC)
uni
uni, thanks a lot
Mathcad Block from the Mathcad Toolbox plugin and just Text inside it for the script.
Edited by user 03 August 2023 09:08:14(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ioncube
#74 Posted : 04 August 2023 21:23:07(UTC)
ioncube
Pakistan
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct
On second note you were correct, I fixed my environment variable under windows %python% now works
Edited by user 04 August 2023 21:24:47(UTC)  | Reason: Not specified
Offline Razonar
#75 Posted : 08 August 2023 08:01:18(UTC)
Razonar
Uruguay
Phase diagrams with CoolProps.
Click to enlarge
PhaseDiagram.sm (40kb) downloaded 19 time(s).
on 08/08/2023(UTC)
Offline Razonar
#76 Posted : 09 August 2023 09:47:50(UTC)
Razonar
Uruguay
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines.
Click to enlarge
PsychrometricChart.sm (126kb) downloaded 20 time(s).
Offline ioncube
#77 Posted : 21 August 2023 23:39:50(UTC)
ioncube
Pakistan
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/...osing-the-phase-optional
First when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent
Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P
Offline mkraska
#78 Posted : 16 April 2024 09:55:20(UTC)
mkraska
It seems that multiple instances of SMath can't use the plugin at the same time.
How to reproduce:
1. Open SMath and access any Coolprop function
2. Open another SMath instance: You get an error message
Guest (3)
4 Pages«<234
