Offline Lupus the Canine
#1 Posted : 07 July 2023 05:12:48(UTC)
Lupus the Canine
Poland
Is it possible to procedurally define variables from strings?
I want to load data to a lot of sets of variables with names following a pattern preferably without doing that manually.
Is there a better way than:
example.sm (5kb) downloaded 5 time(s).?
Edited by user 07 July 2023 05:15:56(UTC)  | Reason: added the image.
#2 Posted : 07 July 2023 11:06:15(UTC)
That's one of the other options.
#3 Posted : 07 July 2023 22:18:37(UTC)
Lupus the Canine
Poland
Thanks, unfortunately value to be assigned is supposed to come from somewhere else, z was just an example because I didn't want to make example with large vectors or matrices to be assigned.
I was looking for a function that would turn a string into a variable that can be used as lhs operand in assignment.
Offline mkraska
#4 Posted : 08 July 2023 02:02:53(UTC)
mkraska
If the value to be assigned is an ordinary expression, then just convert it to a string before using the above-mentioned methods.
asg.sm (5kb) downloaded 7 time(s).
Offline overlord
#5 Posted : 08 July 2023 05:52:52(UTC)
Turkey
Was thanked: 510 time(s) in 340 post(s)
Something like this?
z can be anything and come from anywhere.
As long as it has same length with v.
StrAssign.sm (7kb) downloaded 7 time(s).
Click to enlarge
Edited by user 08 July 2023 16:25:06(UTC)  | Reason: Not specified
#6 Posted : 08 July 2023 23:48:00(UTC)
Lupus the Canine
Poland
Thank you for your help makraska and overlord.
This look great. I will throw eval in there to be sure it is numeric assignment.
#7 Posted : 10 July 2023 15:53:28(UTC)
Thanks, unfortunately value to be assigned is supposed to come from somewhere else ...
I was looking for a function that would turn a string into a variable that can be used as operand in assignment.
algo(col) will deal with mixed import matrix.
You can code to convert mixed or numeric or string.
Select the desired matrix-col.
Subsequently, set your maths.
The attached document SS 6179, I checked it opens 30405.
Please, confirm it opens on your system.
Maths Convert-str2num COL algo.sm (6kb) downloaded 3 time(s).
