Is it possible to procedurally define variables from strings? I want to load data to a lot of sets of variables with names following a pattern preferably without doing that manually. Is there a better way than: example.sm (5kb) downloaded 5 time(s).? Edited by user 07 July 2023 05:15:56(UTC)
| Reason: added the image.
That's one of the other options. |
Originally Posted by: Davide Carpi That's one of the other options. Thanks, unfortunately value to be assigned is supposed to come from somewhere else, z was just an example because I didn't want to make example with large vectors or matrices to be assigned. I was looking for a function that would turn a string into a variable that can be used as lhs operand in assignment.
If the value to be assigned is an ordinary expression, then just convert it to a string before using the above-mentioned methods. asg.sm (5kb) downloaded 7 time(s). |
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Originally Posted by: Lupus the Canine Thanks, unfortunately value to be assigned is supposed to come from somewhere else, z was just an example because I didn't want to make example with large vectors or matrices to be assigned. Something like this? z can be anything and come from anywhere. As long as it has same length with v. Regards StrAssign.sm (7kb) downloaded 7 time(s).Edited by user 08 July 2023 16:25:06(UTC)
| Reason: Not specified
Thank you for your help makraska and overlord. This look great. I will throw eval in there to be sure it is numeric assignment.
Originally Posted by: Lupus the Canine Thanks, unfortunately value to be assigned is supposed to come from somewhere else ... I was looking for a function that would turn a string into a variable that can be used as operand in assignment. algo(col) will deal with mixed import matrix. You can code to convert mixed or numeric or string. Select the desired matrix-col. Subsequently, set your maths. The attached document SS 6179, I checked it opens 30405. Please, confirm it opens on your system. Cheers ... Jean. Maths Convert-str2num COL algo.sm (6kb) downloaded 3 time(s).
