Offline EngMath
#1 Posted : 13 June 2023 12:19:51(UTC)
EngMath
Poland
I'd like to solve the following equation involving matrices for unknown v and θ:
After inputting it in the format used by the Maxima plug-in I get the "no result" message:
Am I doing something wrong ?
Matrix equation.sm (9kb) downloaded 14 time(s).
#2 Posted : 13 June 2023 14:42:27(UTC)
Your setup is not correct.
Offline StvMath
#3 Posted : 13 June 2023 15:18:31(UTC)
StvMath
United Kingdom
Was thanked: 23 time(s) in 20 post(s)
I think the problem is that the units don't match. Compare the units of the components of the two terms inside the brackets that multiply the [v; theta] vector.
#4 Posted : 13 June 2023 15:29:58(UTC)
FindRoots ignores Units. Code the image first.
Solve FindRoots Complex Forum.sm (12kb) downloaded 3 time(s).
Offline EngMath
#5 Posted : 13 June 2023 15:30:57(UTC)
EngMath
Poland
Thank you, I didn't know that I should use the Nonlinear Solvers plug-in instead of the Maxima one.
It works now but the result is surprising. It should be something like v = - 0.021020 for the real part with this input data.
I also suspected the units initially but it didn't work without them either.
Offline StvMath
#6 Posted : 13 June 2023 17:17:16(UTC)
StvMath
United Kingdom
In order to be able to add the two terms they must have the same units. However, omega^2*L doesn't have the same units as EI/L^3. The omega^2*... term seems to be missing a linear mass density (kg/m).
The fact that you might be able to get a numerical result by simply removing the units is irrelevant.
Edited by user 13 June 2023 17:20:06(UTC)  | Reason: Not specified
Offline EngMath
#7 Posted : 13 June 2023 20:55:41(UTC)
EngMath
Poland
Right, I was wondering why density/mass is not included in that equation. Especially since it's included in the equation for tension (the one here is for bending): https://code-aster.org/V...n/man_v/v2/v2.06.101.pdf
Maybe it's a typo and the density should be added before the first omega. Or omega means something different than I assumed (angular frequency).
Edit: I tried calculating mass per unit length based on the density and cross-section area provided in the document and then multiplying it by omega^2 but the result is v = 0,0175 which is still far from the expected value.
Edited by user 13 June 2023 21:21:32(UTC)  | Reason: Not specified
Offline mkraska
#8 Posted : 13 June 2023 22:34:30(UTC)
mkraska
Was thanked: 1127 time(s) in 723 post(s)
Besides correction of the unit mismatch, Solve seems to want the matrix equation in homogeneous form.
Matrix equation_Kr.sm (15kb) downloaded 5 time(s).
Offline Razonar
#9 Posted : 14 June 2023 00:25:48(UTC)
Razonar
Uruguay
Was thanked: 822 time(s) in 520 post(s)
Hi. Another way.
