SMath Studio Forum
Questions
Cannot solve a matrix equation with the Maxima plug-in
Hi, I'd like to solve the following equation involving matrices for unknown v and θ: After inputting it in the format used by the Maxima plug-in I get the "no result" message: Am I doing something wrong ? Matrix equation.sm (9kb) downloaded 14 time(s).
Originally Posted by: EngMath Am I doing something wrong ? Your setup is not correct.
Joined: 26/07/2022(UTC) Posts: 37 Location: UK Was thanked: 24 time(s) in 21 post(s)
I think the problem is that the units don't match. Compare the units of the components of the two terms inside the brackets that multiply the [v; theta] vector.
Originally Posted by: StvMath I think the problem is that the units don't match. Compare the units of the components of the two terms inside the brackets that multiply the [v; theta] vector.
FindRoots ignores Units. Code the image first. Solve FindRoots Complex Forum.sm (12kb) downloaded 3 time(s).
Originally Posted by: Jean Giraud Your setup is not correct. Thank you, I didn't know that I should use the Nonlinear Solvers plug-in instead of the Maxima one. It works now but the result is surprising. It should be something like v = - 0.021020 for the real part with this input data. Originally Posted by: StvMath I think the problem is that the units don't match. Compare the units of the components of the two terms inside the brackets that multiply the [v; theta] vector.
I also suspected the units initially but it didn't work without them either.
In order to be able to add the two terms they must have the same units. However, omega^2*L doesn't have the same units as EI/L^3. The omega^2*... term seems to be missing a linear mass density (kg/m). The fact that you might be able to get a numerical result by simply removing the units is irrelevant.Edited by user 13 June 2023 17:20:06(UTC)
| Reason: Not specified
Originally Posted by: StvMath In order to be able to add the two terms they must have the same units. However, omega^2*L doesn't have the same units as EI/L^3. The omega^2*... term seems to be missing a linear mass density (kg/m). The fact that you might be able to get a numerical result by simply removing the units is irrelevant.
Right, I was wondering why density/mass is not included in that equation. Especially since it's included in the equation for tension (the one here is for bending): https://code-aster.org/V...n/man_v/v2/v2.06.101.pdfMaybe it's a typo and the density should be added before the first omega. Or omega means something different than I assumed (angular frequency). Edit: I tried calculating mass per unit length based on the density and cross-section area provided in the document and then multiplying it by omega^2 but the result is v = 0,0175 which is still far from the expected value. Edited by user 13 June 2023 21:21:32(UTC)
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
Besides correction of the unit mismatch, Solve seems to want the matrix equation in homogeneous form. Matrix equation_Kr.sm (15kb) downloaded 5 time(s). |
Joined: 28/08/2014(UTC) Posts: 1,365 Was thanked: 823 time(s) in 521 post(s)
Hi. Another way. Best regards. Alvaro.
SMath Studio Forum
Questions
