2 Pages12>
Offline JOSEPH7
#1 Posted : 30 September 2021 05:59:19(UTC)
JOSEPH7
Peru
Help!Sad
is there any function to remove all declared variables? similar to clear
Offline oscampo
#2 Posted : 02 October 2021 00:45:30(UTC)
oscampo
Colombia
Was thanked: 87 time(s) in 66 post(s)
Originally Posted by: JOSEPH7 Go to Quoted Post
Help!Sad
You can install the "Special Functions" plugin, which has a Clear() function as you need.
thanks 1 user thanked oscampo for this useful post.
on 02/10/2021(UTC)
Offline Andrey Ivashov
#3 Posted : 02 October 2021 00:51:47(UTC)
Actually this plug-in is built-in into the installer package.
on 02/10/2021(UTC)
Offline overlord
#4 Posted : 02 October 2021 17:36:43(UTC)
Turkey
If SMath would allow to clear variables inside a matrix,
that would be an answer for your request.
But it does not, so this is a dead-end.
For now, you have to make all your variables an element of vector/matrix,
if you want to clear all of them in single command.
Or manually clear them one by one.
Edited by user 02 October 2021 18:42:59(UTC)  | Reason: Not specified
Offline Razonar
#5 Posted : 16 October 2021 21:08:40(UTC)
Razonar
Uruguay
Help!Sad
Hi. I think what the user request is a function similar to "clear all" in Matlab.
Given that include is capable of collecting all the names of the variables of a worksheet as the "whos" command of Matlab would do, perhaps the include code can be used to implement the option to delete all the variables with Clear( "all" ) or something similar.
#6 Posted : 17 October 2021 13:41:24(UTC)
is there any function to remove all declared variables? similar to Clear
Clear(â– ,â– ,â– ,â– ,â– ) ...
clears the system in cause [variables, vectors, matrices]
Clear(x,y,z,m,ω)=1 are evaporated from the system.
Page17 Clear.sm (16kb) downloaded 25 time(s).
#7 Posted : 17 October 2021 18:27:54(UTC)
remove ... you mean clear for reuse ?
Option Find [Ctrl+F] finds numerical single value,
it takes only one search at time, greek not from
palette but copied from palette
Does not distinguish math regions from text.
Not much use for Find.
If the letter is a vector just ignored.
Offline overlord
#8 Posted : 17 October 2021 20:29:26(UTC)
Turkey
Yes Razonar, probably that is the OP's request.
He doesn't want to write every variable into Clear().
Just Clear(ALL) and puff, all defined shall be cleared.
Offline OlliL
#9 Posted : 27 May 2023 22:25:38(UTC)
OlliL
Finland
Hi, sorry to resurrect the thread, just chiming in to say that I would really love a Clear(ALL) function too.
Often it would be nice to use a one SMath file to make multiple repeat calculations but not being able to clear the variables makes repeat calculations extremely risky.
#10 Posted : 28 May 2023 03:17:00(UTC)
The Clear(All) will not clear matrix/vector that are not resident (isolated).
Fromm observation, in that case, set XY the matrix XY:=0
That clears the global system calculation.
#11 Posted : 28 May 2023 15:12:56(UTC)
Not all variables/parameters are declared.
Many reside @ the kernel level, not recognized by Clear(,,,)=
I have an instance that can't be renewed by Clear(,,,)=
Offline OlliL
#12 Posted : 06 June 2023 08:06:54(UTC)
OlliL
Finland
Good morning!
So there is a Clear(All) function? How is it used?
#13 Posted : 06 June 2023 17:27:27(UTC)
Originally Posted by: OlliL Go to Quoted Post
So there is a Clear(All) function ?
How is it used ?
AFAIK, there is no Clear(All) ... what is All ?
Clear(,,,) also restores the built-in.
Maths Clear Restore.sm (10kb) downloaded 15 time(s).
Offline rkronhofer
#14 Posted : 06 October 2023 09:50:47(UTC)
rkronhofer
Hy,
is there any update on such a "Clear(All)" function?
Would be really helpful to have it like this
a:=5
b:=6
Clear(All):=1
a=?
b=?
Thanks for answers
BG
#15 Posted : 06 October 2023 19:31:53(UTC)
Build your system algo style complete wrt parameters
Collapse in utilities, top document.
Now, you are in-situ command line mode ...
Nothing to clear. Just plug parameters in each command line.
Offline overlord
#16 Posted : 08 October 2023 19:55:30(UTC)
Turkey
There is not a Clear(All) function.
No method is applicable to remove all variables at once.
There is not an update, yet.
Unfortunately, I guess none shall appear on horizon soon.
#17 Posted : 09 October 2023 12:45:04(UTC)
CustomFunctions plugin Beta
direct link: https://smath.com/en-US/view/CustomFunctions/download/1.1.8682.22805
Edited by user 09 October 2023 12:55:14(UTC)  | Reason: Not specified
thanks 3 users thanked Davide Carpi for this useful post.
on 09/10/2023(UTC),  on 09/10/2023(UTC),  on 10/10/2023(UTC)
Offline overlord
#18 Posted : 10 October 2023 00:23:22(UTC)
Turkey
This works!!!
Thanks for the beta update.
What would you think about revising output string?
Instead of "1", it can be;
arg==1 --> "All cleared"
arg==2 --> "Variables cleared"
arg==3 --> "Functions cleared"
on 10/10/2023(UTC)
#19 Posted : 10 October 2023 17:54:52(UTC)
Originally Posted by: overlord Go to Quoted Post
This works!!!
You're welcome, glad it seems to work correctly on first try. I still have to check carefully the (2)nd option, since as it is now it deletes "anything that is not a function" (including some low-level stuff).
Usually I prefer a binary output, since can be used inside if/else functions independently from localizations, future enhancements of descriptions, and string comparision issues.
I'll think about it.
Edited by user 10 October 2023 17:57:01(UTC)  | Reason: Not specified
#20 Posted : 11 October 2023 21:49:18(UTC)
If you have discretized [x,y,z ...] in part 1 of project
as that part 1 is complete ... Clear(x,y,z) for next part of the project.
Assume part 1 & part 2 are constructed around 5 parameters.
If you ClearAll(,,,,,) past part 1
You have to re-install those 5 parameters that over-ride
themselves from the new ones.
Guest (2)
2 Pages12>
