Joined: 21/11/2020(UTC) Posts: 1 Location: AREQUIPA 04000
Help! is there any function to remove all declared variables? similar to clear
Joined: 10/12/2009(UTC) Posts: 246 Location: Cali, Colombia Was thanked: 85 time(s) in 65 post(s)
Originally Posted by: JOSEPH7 Help! is there any function to remove all declared variables? similar to clear You can install the "Special Functions" plugin, which has a Clear() function as you need.
1 user thanked oscampo for this useful post.
Originally Posted by: oscampo You can install the "Special Functions" plugin, which has a Clear() function as you need. Actually this plug-in is built-in into the installer package.
If SMath would allow to clear variables inside a matrix, that would be an answer for your request. But it does not, so this is a dead-end. For now, you have to make all your variables an element of vector/matrix, if you want to clear all of them in single command. Or manually clear them one by one. Regards Edited by user 02 October 2021 18:42:59(UTC)
| Reason: Not specified
Originally Posted by: JOSEPH7 Help! is there any function to remove all declared variables? similar to clear Hi. I think what the user request is a function similar to "clear all" in Matlab. Given that include is capable of collecting all the names of the variables of a worksheet as the "whos" command of Matlab would do, perhaps the include code can be used to implement the option to delete all the variables with Clear( "all" ) or something similar. Best regards Alvaro.
Originally Posted by: JOSEPH7 is there any function to remove all declared variables? similar to Clear Clear(■,■,■,■,■) ... clears the system in cause [variables, vectors, matrices] Clear(x,y,z,m,ω)=1 are evaporated from the system. Page17 Clear.sm (16kb) downloaded 25 time(s).
Originally Posted by: JOSEPH7 is there any function to remove all declared variables? similar to clear remove ... you mean clear for reuse ? Option Find [Ctrl+F] finds numerical single value, it takes only one search at time, greek not from palette but copied from palette Does not distinguish math regions from text. Not much use for Find. If the letter is a vector just ignored.
Originally Posted by: Razonar Hi. I think what the user request is a function similar to "clear all" in Matlab. Yes Razonar, probably that is the OP's request. He doesn't want to write every variable into Clear(). Just Clear(ALL) and puff, all defined shall be cleared. Regards
Hi, sorry to resurrect the thread, just chiming in to say that I would really love a Clear(ALL) function too. Often it would be nice to use a one SMath file to make multiple repeat calculations but not being able to clear the variables makes repeat calculations extremely risky.
Originally Posted by: JOSEPH7 is there any function to remove all declared variables? similar to clear The Clear(All) will not clear matrix/vector that are not resident (isolated). Fromm observation, in that case, set XY the matrix XY:=0 That clears the global system calculation.
Originally Posted by: JOSEPH7 is there any function to remove all declared variables? similar to Clear Not all variables/parameters are declared. Many reside @ the kernel level, not recognized by Clear(,,,)= I have an instance that can't be renewed by Clear(,,,)=
Originally Posted by: Jean Giraud Originally Posted by: JOSEPH7 is there any function to remove all declared variables? similar to Clear Not all variables/parameters are declared. Many reside @ the kernel level, not recognized by Clear(,,,)= I have an instance that can't be renewed by Clear(,,,)= Good morning! So there is a Clear(All) function? How is it used?
Originally Posted by: OlliL So there is a Clear(All) function ? How is it used ? AFAIK, there is no Clear(All) ... what is All ?Clear(,,,) also restores the built-in. Cheers ... Jean. Maths Clear Restore.sm (10kb) downloaded 15 time(s).
Hy, is there any update on such a "Clear(All)" function? Would be really helpful to have it like this a:=5 b:=6 Clear(All):=1 a=? b=? Thanks for answers BG
Originally Posted by: OlliL Often it would be nice to use a one SMath file to make multiple repeat calculations but not being able to clear the variables makes repeat calculations extremely risky. Build your system algo style complete wrt parameters Collapse in utilities, top document. Now, you are in-situ command line mode ... Nothing to clear. Just plug parameters in each command line.
Originally Posted by: OlliL So there is a Clear(All) function? There is not a Clear(All) function. No method is applicable to remove all variables at once. Originally Posted by: rkronhofer is there any update on such a "Clear(All)" function? There is not an update, yet. Unfortunately, I guess none shall appear on horizon soon. Regards
3 users thanked Davide Carpi for this useful post.
on 09/10/2023(UTC), on 09/10/2023(UTC), on 10/10/2023(UTC)
This works!!! Thanks for the beta update.
What would you think about revising output string? Instead of "1", it can be; arg==1 --> "All cleared" arg==2 --> "Variables cleared" arg==3 --> "Functions cleared"
Originally Posted by: overlord This works!!! Thanks for the beta update. You're welcome, glad it seems to work correctly on first try. I still have to check carefully the (2)nd option, since as it is now it deletes "anything that is not a function" (including some low-level stuff). Originally Posted by: overlord What would you think about revising output string? Instead of "1", it can be; arg==1 --> "All cleared" arg==2 --> "Variables cleared" arg==3 --> "Functions cleared" Usually I prefer a binary output, since can be used inside if/else functions independently from localizations, future enhancements of descriptions, and string comparision issues. I'll think about it. Edited by user 10 October 2023 17:57:01(UTC)
Originally Posted by: JOSEPH7 is there any function to remove all declared variables? similar to clear If you have discretized [x,y,z ...] in part 1 of project as that part 1 is complete ... Clear(x,y,z) for next part of the project. Assume part 1 & part 2 are constructed around 5 parameters. If you ClearAll(,,,,,) past part 1 You have to re-install those 5 parameters that over-ride themselves from the new ones.
