23 Pages«<212223
Offline uni
#441 Posted : 28 April 2023 20:22:34(UTC)
uni
You need to show me MapleTools.log file inside MapleTools directory. It appears then you close the SMath and set Debug to True in MapleTools.config file.
maple-system-python-math.sm (6kb) downloaded 11 time(s).
Edited by user 28 April 2023 21:23:41(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline overlord
#442 Posted : 28 April 2023 21:52:06(UTC)
Turkey
Here is log file.
Offline uni
#443 Posted : 28 April 2023 21:59:15(UTC)
uni
Try to add full path to python. I think the problem is in the paths. You need to understand how the python is called and what path to the script file is passed to it.
Edited by user 28 April 2023 22:02:59(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#444 Posted : 29 April 2023 08:38:38(UTC)
uni
Click to enlarge
maple-system-tools.sm (18kb) downloaded 104 time(s).
Russia ☭ forever
on 29/04/2023(UTC)
Offline uni
#445 Posted : 29 April 2023 19:41:22(UTC)
uni
Click to enlarge
maple-system-tools-with-TextRegion.sm (17kb) downloaded 18 time(s).
Russia ☭ forever
on 30/04/2023(UTC)
Offline Razonar
#446 Posted : 30 April 2023 07:49:29(UTC)
Razonar
Uruguay
This requires install numpy and matplotlib under python. Code of the example from here. A lot of examples for matplotlib here. Also, notice that the python window is interactive.
Click to enlarge
matplotlib.sm (6kb) downloaded 28 time(s).
on 30/04/2023(UTC),  on 04/05/2023(UTC)
Offline uni
#447 Posted : 30 April 2023 13:34:33(UTC)
uni
Gnuplot.
You can install it using scoop: scoop install gnuplot
Click to enlarge
maple-system-gnuplot.sm (15kb) downloaded 23 time(s).
Russia ☭ forever
Offline uni
#448 Posted : 04 May 2023 15:46:38(UTC)
uni
For better use Text Region uncheck this menu item.
Click to enlarge
Russia ☭ forever
on 04/05/2023(UTC)
Offline uni
#449 Posted : 05 May 2023 10:31:58(UTC)
uni
Theoretically, we can connect ngspice for the calculation of electrical circuits.
Links:
1. ngspice - open source spice simulator
2. Ngspice example using py4spice package
Russia ☭ forever
Offline uni
#450 Posted : 05 May 2023 11:07:27(UTC)
uni
Now let's add modes.
Click to enlarge
maple-python-mode.sm (12kb) downloaded 14 time(s).
Edited by user 05 May 2023 16:13:47(UTC)  | Reason: Not specified
Russia ☭ forever
on 06/05/2023(UTC)
Offline uni
#451 Posted : 05 May 2023 20:34:22(UTC)
uni
Click to enlarge
MapleToolsVersion.sm (16kb) downloaded 20 time(s).
Russia ☭ forever
on 06/05/2023(UTC)
Offline charlamb
#452 Posted : 05 May 2023 23:13:31(UTC)
charlamb
Rank: Member
Brazil
Hi, Uni.
This is just a newbie question but how do I insert the code from your last post?
thanks 1 user thanked charlamb for this useful post.
on 08/05/2023(UTC)
Offline uni
#453 Posted : 06 May 2023 06:27:58(UTC)
uni
Originally Posted by: charlamb Go to Quoted Post
Hi, Uni.
Use Text Region and Mathcad Block. Uncheck menu items with auto helpers and past the code from example. Set the operation for Mathcad Block to mat from the context menu. The Mathcad Block should cover the Text Region. In other words, the Text Region should be inside the frame of the Mathcad Block. It is important.
Edited by user 06 May 2023 08:28:11(UTC)  | Reason: Not specified
Russia ☭ forever
on 06/05/2023(UTC),  on 08/05/2023(UTC)
Offline charlamb
#454 Posted : 08 May 2023 00:25:50(UTC)
charlamb
Rank: Member
Brazil
Thanks, Uni.
It worked!
Offline uni
#455 Posted : 11 May 2023 16:03:27(UTC)
uni
Simplified (complicated).
Click to enlarge
maple-python-mode.sm (12kb) downloaded 25 time(s).
Russia ☭ forever
on 12/05/2023(UTC),  on 12/05/2023(UTC)
Offline Razonar
#456 Posted : 28 October 2023 20:26:31(UTC)
Razonar
Uruguay
Hi. Usually, evalf (eval as float number) returns wrong results. Is there some workaround, like getting the string, or is it a bug which needs some solution?
Thanks in advance.
on 28/10/2023(UTC)
Offline uni
#457 Posted : 29 October 2023 22:59:39(UTC)
uni
SMath can't convert a string to a number.
Try this
Russia ☭ forever
on 30/10/2023(UTC),  on 30/10/2023(UTC)
Offline Razonar
#458 Posted : 30 October 2023 03:30:56(UTC)
Razonar
Uruguay
Originally Posted by: uni Go to Quoted Post
... Try this
Thanks, Viacheslav! convert fractional works fine.
Guest (4)
23 Pages«<212223
