Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 508 time(s) in 338 post(s)
Here is log file.
Code:28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] SMath Studio Desktop 64-bit 1.0.8348.30405
28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] Maple Tools, version 1.1.8517.16356, 27-Apr-2023 09:05:12
28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] OS: Unix 6.1.25.1
28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] .Net: 4.0.30319.42000
28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] maple(1) - evaluate symbolic expression.
28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] Successfully. 1 function(s) loaded.
28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] Maple commander: /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe
28.04.2023 21:46:25 [INFO ] [Plugin.Initialize()] Temp directory: ./tmp
28.04.2023 21:46:29 [INFO ] [->] map2(writeline,"./tmp/test.py",convert(smath_mat("import math; print( math.erf(0.74) )",1,1),vector))
28.04.2023 21:46:29 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:46:32 [INFO ] [<-]
28.04.2023 21:46:32 [INFO ] [<-] mat(37,1,1)
28.04.2023 21:46:32 [INFO ] [->] convert(op(2,ssystem("\"python ./tmp/test.py\"")),symbol)
28.04.2023 21:46:32 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:46:34 [INFO ] [<-]
28.04.2023 21:46:34 [INFO ] [->] map2(writeline,"./tmp/test.py",convert(smath_mat("import math","print( math.erf(0.65) )",2,1),vector))
28.04.2023 21:46:34 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:46:37 [INFO ] [<-]
28.04.2023 21:46:37 [INFO ] [<-] mat(12,24,2,1)
28.04.2023 21:46:37 [INFO ] [->] convert(op(2,ssystem("\"python ./tmp/test.py\"")),symbol)
28.04.2023 21:46:37 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:46:40 [INFO ] [<-]
28.04.2023 21:46:40 [INFO ] [->] smath_int(28561/160000,13/20)
28.04.2023 21:46:40 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:46:42 [INFO ] [<-]
28.04.2023 21:46:42 [INFO ] [<-] proc()submatrix(el(args,1),el(args,2)..el(args,3),el(args,4)..el(args,5))endproc
28.04.2023 21:46:53 [INFO ] [->] smath_int(x^4,x)
28.04.2023 21:46:53 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:46:55 [INFO ] [<-]
28.04.2023 21:46:55 [INFO ] [<-] 1/5*x^5
28.04.2023 21:46:58 [INFO ] [->] smath_int(x^4,x)
28.04.2023 21:46:58 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:47:00 [INFO ] [<-]
28.04.2023 21:47:00 [INFO ] [<-] 1/5*x^5
28.04.2023 21:47:04 [INFO ] [->] smath_int(x^14,x)
28.04.2023 21:47:04 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:47:07 [INFO ] [<-]
28.04.2023 21:47:07 [INFO ] [<-] 1/15*x^15
28.04.2023 21:47:19 [INFO ] [->] smath_int(x^14,x)
28.04.2023 21:47:19 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:47:21 [ERROR] 008c:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
008c:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
008c:err:systray:initialize_systray Could not create tray window
0114:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
0114:err:winediag:nodrv_CreateWindow L"Make sure that your X server is running and that $DISPLAY is set correctly."
28.04.2023 21:47:21 [INFO ] [<-]
28.04.2023 21:47:21 [INFO ] [<-] 1/15*x^15
28.04.2023 21:47:24 [INFO ] [->] smath_int(x^13,x)
28.04.2023 21:47:24 [INFO ] /home/username/.config/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.1.8517.16356/bin/cmaple.exe ./tmp/in.tmp
28.04.2023 21:47:26 [ERROR] 008c:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
28.04.2023 21:47:26 [INFO ] [<-]
28.04.2023 21:47:26 [INFO ] [<-] 1/14*x^14
