My Setup= Windows 7 4Gb RAM 64 Bit
I get the following:
Solver has Stopped Working
Then get 2 Options
Close the Program Debug the Program
Please Advice What to Do ?
Regards ABA
It happens on program start? After loading a worksheet? |
It Happens on Program Start. ... for me it is a Puzzle ... Thanks for trying to Help. .. Regards ABA
As first step you can choose the "Debug" option and see if it returns a stack trace (list of code functions involved to some degree with the issue). If it happens copy and paste it here. As second step, with SMath closed, open a explorer window and in the address bar type then press return. There should be a "SMath" folder, rename it as something else (f.e. SMath_backup) and try to start the program again. |
Thanks Again . When I choose "Debug" nothing Happens ...?! . Regards ABA
Joined: 11/01/2018(UTC) Posts: 133 Location: Wisconsin Was thanked: 61 time(s) in 38 post(s)
Greetings, Originally Posted by: xlguru It Happens on Program Start. ... Just so we are all on the same page, what scenario are you currently experiencing? - This the first time using SMath (Just downloaded/installed it) and it does not work
- I have been using SMath, and today it just stopped working
- Were you informed "New Version Available" and you clicked to install?
- Did you just install a new plugin?
- Did you attempting adding/changing settings in the Program Folders (e.g., Units.xml)?
If possible, please list the SMath Version you are currently using/installed; answers may change depending if you are using the latest stable version, or a beta version, or a version before v1.00 Kenny Lemens, P.E. ᵂᴵ |
Hi, My case is : This the first time using SMath (Just downloaded/installed it) and it DOES NOT WORK . Which Version ?: This is the File I downloaded recently for Installation (Can not Run it to get more Details) Version 1.0.8348 - Stable (released at 11.9.2022)
Kindly note I have used previous versions of Smath and they worked Nicely . Thanks for your Effort .. Warm Regards ... ABA
Originally Posted by: xlguru When I choose "Debug" nothing Happens ...?! Ok, it was worth to give it a try. Have you tried this? Originally Posted by: Davide Carpi As second step, with SMath closed, open a explorer window and in the address bar type then press return. There should be a "SMath" folder, rename it as something else (f.e. SMath_backup) and try to start the program again. |
WOW ... It Worked ...WOW . THANK YOU VERY MUCH . Regards .... ABA
Very good, then it was some extension messing up. Since you are a fresh user you can probably delete safely the old folder (it contains the extensions downloaded for your account and their settings, as well as f.e. the output data of built-in file writing functions) Edited by user 23 February 2023 21:12:40(UTC)
| Reason: Typo, marked as solved |
Hi, Thank You for the Follow-Up, you must be having a Deep and Clear understanding of the Product. . May I suggest you write a book about Smath. . Warm Regards ... ABA
