Hey guys, im trying to plot my function with x-yplot (addon) but it doesnt work. I will be happy if can someone can help me. i define two functions (with If-clauses) and now I have to put it in x-y-plot. Thanks for helping Pfahlsetzungslinie.sm (102kb) downloaded 19 time(s).
Originally Posted by: Beyaz I define two functions (with If-clauses) and now I have to put it in x-y-plot. 1. Start by the first red instance ... assign the demand. 2. For the plot Units don't match3. Check if your incomplete Bolean is OK ... here shown complete. 4. What is mPa
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
If you want to plot, you have to eliminate units. Either by writing a unitless function, or using units while plotting. I would rather second one. Regards Pfahlsetzungslinie.sm (113kb) downloaded 11 time(s).
hey guys thanks. (i tryed to give you a thanks but i always get an error) it works now. Ive realized my mistakes. i have 2 more question. 1. is it possible to rotate the graph or function? I wanna switch x and y axis 2. i wanna make the visible spectrum of x and y axis depent on a variable. like X-Axis Max=s1 and Min=s2 //sorry for my bad english
Originally Posted by: Beyaz i have 2 more question. 1. is it possible to rotate the graph or function? I wanna switch x and y axis 2. I wanna make the visible spectrum of x and y axis depend on a variable. like X-Axis Max=s1 and Min=s2 I understand 1 ... 2 Not clear. Cheers ... Jean.
... once the discrete data set in hand, you can rotate by any angle as desired.
Originally Posted by: Beyaz 2. I wanna make the visible spectrum of x and y axis depend on a variable. like X-Axis Max=s1 and Min=s2
If I understand: once the discrete data set in hand, very easy to range between Mi/Max. Produce the discrete data set, I will terminate. Cheers ... Jean.
Joined: 28/08/2014(UTC) Posts: 1,371 Was thanked: 834 time(s) in 528 post(s)
Originally Posted by: Beyaz ... i have 2 more question. 1. is it possible to rotate the graph or function? I wanna switch x and y axis 2. i wanna make the visible spectrum of x and y axis depent on a variable. like X-Axis Max=s1 and Min=s2 Hi Beyaz. 1. Yes. For example you can use this technique over your functions xy-yx-plot.sm (8kb) downloaded 8 time(s).2. Yes. For example you can try to learn about how to use setprop in an XY plot region. Best regards. Alvaro.
Hi. You need to specify the XYPlot index. This is how to swap axis coordinates, and reverse the y-axis. I reduce the number of points in the XYPlot to 50. Pfahlsetzungslinie1.sm (88kb) downloaded 10 time(s).Best regards. Alvaro.
Originally Posted by: Beyaz But to rotate the graph like this it didn't work. I tried your suggestions. You haven't produced the discrete data set. Cheers ... Jean. Wanna Rotate.sm (15kb) downloaded 3 time(s).
You can also use a rotation matrix. It works on both 2DPlot an XYplot. Regards
thanks all of you guys.
now my smath tool is perfect. thanks for helping.
