Offline netsonicyxf
#1 Posted : 17 January 2023 17:23:15(UTC)
netsonicyxf
The logarithmic plot on the top of the image shows 0.1, 0.5, 1, 5 and 10 on both x and y axis (log scale).
I insert a Zedgraph, and set 0.1 to min and 10 to max, as shown in the image.
But the lables on Y axis has two 10^-1 and two 10^1, while lables on X axis has only one 10^-1.
How to show 0.1, 0.5, 1, 5 and 10 on both x and y axis?
PS. The two 45 degree axises for Rd and Ra on the top image are ingored in Smath.
Worksheet2.sm (37kb) downloaded 14 time(s).
Edited by user 18 January 2023 05:44:57(UTC)  | Reason: Not specified
#2 Posted : 17 January 2023 18:27:21(UTC)
Too many things are missing in there !
Offline netsonicyxf
#3 Posted : 18 January 2023 05:39:35(UTC)
netsonicyxf
Which things are missing?
#4 Posted : 18 January 2023 17:12:27(UTC)
Originally Posted by: netsonicyxf Go to Quoted Post
Which things are missing ?
These two work well.
2DPlots ZedGraph log-log.sm (100kb) downloaded 10 time(s).
Laplace Admittance.sm (154kb) downloaded 7 time(s).
Offline Kenny Lemens
#5 Posted : 19 January 2023 21:13:26(UTC)
Kenny Lemens
Was thanked: 62 time(s) in 39 post(s)
Greetings,
I would encourage you to review Overlord's post on the following forum: https://en.smath.com/for...mic-scale.aspx#post70646
- In short, you might want to consider the use of the 「X-Y Plot Region」 Plugin might serve you better than 「Zedgraph」.
In the case you cannot format the axis labels as you so desire, you also have the ability/option to insert text and draw lines on the graph; thus creating your own axis data (technically plotted data, but it would appear as expected). On that note, you can also draw in those lines at the 45°; just need to draw a line with regards to your axes being calibrated in log cycles: (https://geology.humboldt.../equations_of_graphs.pdf)
Hope this helps!
-Kenny Lemens, P.E. ᵂᴵ
Offline overlord
#6 Posted : 20 January 2023 05:17:18(UTC)
Turkey
I don't know how to easily rotate text in XYPlot or even it is possible.
But a lot of portion of your function can be plotted by mentioned method.
I am not sure accuracy of crossline ticks however.
I only implemented it to show this can be done.
PS: Refreshed with spline plots.
Worksheet2.sm (35kb) downloaded 28 time(s).
Edited by user 20 January 2023 05:32:29(UTC)  | Reason: Not specified
thanks 5 users thanked overlord for this useful post.
on 20/01/2023(UTC),  on 20/01/2023(UTC),  on 20/01/2023(UTC),  on 20/01/2023(UTC),  on 07/07/2023(UTC)
Offline Razonar
#7 Posted : 20 January 2023 05:55:45(UTC)
Razonar
Uruguay
Originally Posted by: overlord Go to Quoted Post
... Worksheet2.sm (35kb) downloaded 28 time(s). ...
Wow!
