SMath Studio Forum
Questions
How to show specific lables on axis in logarithmic plot?
The logarithmic plot on the top of the image shows 0.1, 0.5, 1, 5 and 10 on both x and y axis (log scale). I insert a Zedgraph, and set 0.1 to min and 10 to max, as shown in the image. But the lables on Y axis has two 10^-1 and two 10^1, while lables on X axis has only one 10^-1. How to show 0.1, 0.5, 1, 5 and 10 on both x and y axis? PS. The two 45 degree axises for Rd and Ra on the top image are ingored in Smath. Worksheet2.sm (37kb) downloaded 14 time(s).Edited by user 18 January 2023 05:44:57(UTC)
| Reason: Not specified
Too many things are missing in there !
Which things are missing?
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings, I would encourage you to review Overlord's post on the following forum: https://en.smath.com/for...mic-scale.aspx#post70646- In short, you might want to consider the use of the 「X-Y Plot Region」 Plugin might serve you better than 「Zedgraph」.
In the case you cannot format the axis labels as you so desire, you also have the ability/option to insert text and draw lines on the graph; thus creating your own axis data (technically plotted data, but it would appear as expected). On that note, you can also draw in those lines at the 45°; just need to draw a line with regards to your axes being calibrated in log cycles: ( https://geology.humboldt.../equations_of_graphs.pdf) Hope this helps! -Kenny Lemens, P.E. ᵂᴵ |
Originally Posted by: Kenny Lemens I would encourage you to review Overlord's post on the following forum: I don't know how to easily rotate text in XYPlot or even it is possible. But a lot of portion of your function can be plotted by mentioned method. I am not sure accuracy of crossline ticks however. I only implemented it to show this can be done. Regards PS: Refreshed with spline plots. Worksheet2.sm (35kb) downloaded 28 time(s).Edited by user 20 January 2023 05:32:29(UTC)
5 users thanked overlord for this useful post.
on 20/01/2023(UTC), on 20/01/2023(UTC), on 20/01/2023(UTC), on 20/01/2023(UTC), on 07/07/2023(UTC)
Originally Posted by: overlord Wow! Best regards. Alvaro.
SMath Studio Forum
Questions
