Hello, I was looking for a similar topic on the forum, but I couldn't find it. Is it possible to draw such a graph. Graphs.sm (5kb) downloaded 28 time(s).
Originally Posted by: mareksss Is it possible to draw such a graph. Yes it is possible. Here is your request. Regards Graphs_1.sm (5kb) downloaded 38 time(s).Edited by user 17 October 2022 22:34:49(UTC)
| Reason: Not specified
2 users thanked overlord for this useful post.
on 17/10/2022(UTC), on 18/10/2022(UTC)
Hi. Just another way, in addition to the solutions offered by Overlord and Pompelmo, using the ability of XYPlot plugin for plot parametric curves, as is explained here. XYPlot Parametric.sm (6kb) downloaded 26 time(s).Best regards. Alvaro.
Originally Posted by: mareksss Is it possible to draw such a graph. ... export your creation Cheers ... Jean. Utilities XY plot [Butterfly].sm (30kb) downloaded 14 time(s).
Originally Posted by: Razonar using the ability of XYPlot plugin for plot parametric curves Parametric ability is a good addition. I wish 2D-Plot has this feature too. I also would like animation for XY-Plot.
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
The Maxima plugin provides plotting functions, among them parametric plots. For details look for "kraska smath handbuch". Note that there seems to be a png export glitch. The region t:=25 is disabled in the sheet but not grayed out in the export (image below). The parameter variable obviously must be undefined, otherwise the x and y expressions are just numbers. para.sm (138kb) downloaded 11 time(s). |
I have no recollection of Parametric Engineering project(s). Whatever, this document advances your Parametric Journey.Ultimately, export the project as a standard data table for publishing. ... offered up to the derivatives of the piece-wise project. Comments, more help ... Welcome. Cheers ... Jean. Utilities XY plot Parametric.sm (90kb) downloaded 9 time(s).
