23 Pages<1234>»
Online oscampo
#21 Posted : 26 September 2012 23:16:36(UTC)
oscampo
Colombia
Was thanked: 87 time(s) in 66 post(s)
Originally Posted by: uni Go to Quoted Post
Originally Posted by: omorr Go to Quoted Post
Hello uni
Originally Posted by: oscampo Go to Quoted Post
Please, Uni or Omorr, could you translate the text on the image on first post?
Thanks a lot
oscampo
Thank you for your efforts on this but, unfortunately, there is no way for me to understand how is this working and how should this plugin be used Sad .
Ok. I'll make simple video tutorial.
Hi Uni, I was trying again with your plugin, but I have a problem: This plugin is not compatible with windows 7
Sad
Offline uni
#22 Posted : 27 September 2012 05:28:31(UTC)
uni
Try to change the environment variable TEMP (TMP) to c:\temp (short path). And run the program with administrator privileges.
Edited by user 27 September 2012 05:37:30(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline omorr
#23 Posted : 27 September 2012 08:02:48(UTC)
omorr
Serbia
Hello uni,
By changing TMP,TEMP variables it works now for me (WinXP(32)) Good
Just could not believe it was that simple Shok
maple(dsolve(diff(y(x),x)+5*y(x)≡3*x,y(x)))=y(x)={3*(-1+5*x)+25*exp(-5*x)*_C1}/25
maple(int(1/x,x))=ln(x)
Thank you,
EDIT:
On Win7(64) (I changed TMP,TEMP variables) the following error appeared - first picture attached.
I have the Administrator privileges, of course. If I run SMath as Administrator, error apperaed - second picture attached
Edited by user 27 September 2012 09:58:57(UTC)  | Reason: Not specified
on 28/09/2012(UTC)
Offline omorr
#24 Posted : 27 September 2012 10:52:19(UTC)
omorr
Serbia
Just a reminder on this post about wrong mixed derivatives
See please the results using maple plugin by uni -(unfortunately, it seems it is not working on Win7(64) or I do not know how to make it work) and by SMath. SMath is doing this wrong and I hope this will be corrected in the next SMath release.
Offline uni
#25 Posted : 27 September 2012 15:44:33(UTC)
uni
Radovan, plugin doesn't support nested expressions yet (see file mvr4.txt with intermediate calculations). This means that you can not use functions, because mapledos.exe not see them (need to finish, I hope it will be in the next release):
27.09.2012 18:33:09 [->] diff(diff(f(x;y);y);x)
27.09.2012 18:33:09 [->] C:\Temp\tmp8C7.tmp:
interface(quiet=true);
writeto(`C:\\Temp\\tmp8C8.tmp`):
sys := proc() { args[i] $ i = 1..nargs-2 }; end:
ans := diff(diff(f(x,y),y),x):
if ( whattype( ans ) = `exprseq` ) then convert( cat( `mat(`, substring( convert( [ans], string ), 2..-2 ), `,`, nops( [ans] ), `,1)` ), string ); elif ( whattype( ans ) = `set` ) then convert(cat(`mat(`,substring(convert(map2(op,2,[ans[i]$i=1..nops(ans)]),string),2..-2),`,`,nops(ans),`,1)`),string);else convert( ans, string ); fi;
quit:
27.09.2012 18:33:13 [<-] C:\Temp\tmp8C8.tmp:
diff(diff(f(x,y),x),y)
27.09.2012 18:33:13 [<-] diff(diff(f(x;y);x);y)
As for the 64-bit version, I'll think about it.
Russia ☭ forever
on 27/09/2012(UTC)
Offline uni
#26 Posted : 27 September 2012 18:25:02(UTC)
uni
Update: mvr4_20120927.zip
If you want to use function from SMath Studio write this: int(sin(x),x) or maple(int(sin(x),x)) - it will be the same.
But If you want to use function from Maple V R4 (DOS) write this: maple("int"(sin(x),x)) it will not be equivalent to maple(int(sin(x),x)) (preprocessing is done before calling maple()).
P.S. I still think how to do better Umnik .
Edited by user 27 September 2012 18:52:42(UTC)  | Reason: Not specified
Russia ☭ forever
on 27/09/2012(UTC)
Offline omorr
#27 Posted : 27 September 2012 19:27:02(UTC)
omorr
Serbia
Hello uni,
Wish you all the best about it.
By the way, is there any chance that plugins you and other good people made Good Thank you could be available in one place and not scattered through the Forum . I suppose that at list new forum like "User plugins" could be made and all the user plugins available for using to be put there. As far I know all the plugins are in the "Samples" among many other topics.
Maybe Andrey could open a new "User plugins" Forum for instance Unsure
on 28/09/2012(UTC)
Offline uni
#28 Posted : 27 September 2012 19:43:02(UTC)
uni
Radovan, I added a link in the signature.
Russia ☭ forever
Offline omorr
#29 Posted : 27 September 2012 21:13:12(UTC)
omorr
Serbia
Ah yes, I see - did not see that sorry Blush
Thank you very much - I will keep your link as a reference for all your very useful plugins Biggrinrinks:
Thank you very much,
Offline uni
#30 Posted : 27 September 2012 21:16:45(UTC)
uni
I added it today Biggrin
Russia ☭ forever
Offline adiaz
#31 Posted : 28 September 2012 06:54:17(UTC)
adiaz
Rank: Member
Was thanked: 5 time(s) in 5 post(s)
Try this one: mvr4_20120926.zip. In the plugins folder there is a log file of transformations: mvr4.txt. Don't forget to check it periodically.
Thanks. Testing ...
thanks 1 user thanked adiaz for this useful post.
on 28/09/2012(UTC)
Offline adiaz
#32 Posted : 28 September 2012 07:56:51(UTC)
adiaz
Rank: Member
Hi. I dislake M54IV (the last version which use old Mathcad versions). But love M5R5. That version have a different notation for strings, more like the new versions of others softwares. Also, it works in Windows 3 version, for 16 bits, but with the extension for 32 bits. Even I don't understand how use the semicolon in the uni examples, here is the result replacing mapledos.exe, and lib and licence folders with this version.
adiaz attached the following image(s):
Offline uni
#33 Posted : 28 September 2012 08:07:51(UTC)
uni
Could you show the contents of the file mvr4.txt?
Many years ago there was even a website called "Maple bugs". It had a lot of them.
Russia ☭ forever
Offline adiaz
#34 Posted : 28 September 2012 08:22:39(UTC)
adiaz
Rank: Member
Sure, here it is.
File Attachment(s):
mvr4.txt (66kb) downloaded 74 time(s).
on 28/09/2012(UTC)
Offline uni
#35 Posted : 28 September 2012 08:30:17(UTC)
uni
Sure, here it is.
I forgot that I also have cmaple.exe. Thanks for reminding me, I'll change the plugin to support the "Maple V Release 5". As for the semicolon, you can just write a comma. It depends on the settings in SMath Studio.
Russia ☭ forever
Offline adiaz
#36 Posted : 28 September 2012 08:45:59(UTC)
adiaz
Rank: Member
It can be great, and I agree with you about to not convert smath in a kind of fronten or front cover to call others programs. But in the meantime that have not some functions, like indefinite integrals, maybe the best way in call some external program could be use a wrapper function (like Eval or Parse) inside of smath, where each user can configure it's oun kernel (maxima, yacas, ...).
Ah, and thanks for remember me the smath configuration.
Offline adiaz
#37 Posted : 28 September 2012 09:00:01(UTC)
adiaz
Rank: Member
Can´t call the function with two args. (Pila vacía = empty stack)
Regards.
Offline uni
#38 Posted : 28 September 2012 09:08:36(UTC)
uni
statement Biggrin
Wait for a while, I'll change the plugin and then you'll can use it normally.
Russia ☭ forever
Offline adiaz
#39 Posted : 28 September 2012 09:23:40(UTC)
adiaz
Rank: Member
jajaja. It's late and it's raining. Thanks.
Offline omorr
#40 Posted : 28 September 2012 11:27:15(UTC)
omorr
Serbia
It worked few hours ago and now do not Sorry - hope this is temporarily Shok
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: ftp://82.193.156.30/SMath/plugins
The following error was encountered:
Connection to 82.193.156.30 Failed
The system returned:
(113) No route to host
The remote host or network may be down. Please try the request again.
Your cache administrator is root.
Generated Fri, 28 Sep 2012 08:26:00 GMT by proxy.uns.ac.rs (squid/2.6.STABLE21)
Guest (2)
23 Pages<1234>»
