SMath Studio Forum
Questions
Split Areas(Polygons convex and concave) by lines
Hi everyone ,I'm doing a momentum curvature usign Popovic's Method and found a big problem beacuse to divide a polygon(convex and concave) into small fiber like this image but with more lines: it's not so easy to do an algorithm. I did a smath file when the polygon it's rectangular but for more general case my smath code doesn't work, I'd like know an algorithm, code or function if it's posible in smath or other language to develop. Best regards. Jesus. Verificacion_de_fluencia_en_acero_fiber_method_degradation_forum.pdf (551kb) downloaded 27 time(s).Edited by user 29 July 2022 19:31:21(UTC)
| Reason: Not specified
If I understand ... Your polygon has 9 vertices, we can try a circular spline. That will add as many points between vertices, is it ? From there: Area, Perimeter, Center of Gravity. Give the vertices... Jean.
Hi Jean, exactly I need to known the area, center of gravity and perimeter of the division but the polygon doesn't need to have 9 vertices, this is an example in this case. In general ,I'd like to calculate for n vertices polygon(convex or concave),let me give an example in smath for regular polygon. polygon_2.sm (37kb) downloaded 10 time(s).Best regards. Jesus. Edited by user 30 July 2022 06:30:45(UTC)
| Reason: Adding and plotting polygon convex and concave
Hi Jean, it was a good solution and you give some ideas to do a code but I'd like to do for more lines and I'd like to optimize the code or algorithm. I did a code in smath maybe need to optimize some parts and get some interesting results, i hope you take a look because a I'd like to aply to convex and no convex polygon, I think it's so hard but I'd like to know the algorithm or code that other programs use. My code doesn't work for some slopes though Page5 Polygon Copy.sm (117kb) downloaded 12 time(s).Best regards. Jesus. Edited by user 31 July 2022 02:48:47(UTC)
| Reason: correction
Joined: 15/04/2012(UTC) Posts: 1,996 Was thanked: 1132 time(s) in 727 post(s)
Originally Posted by: Jesus_Solano Hi everyone ,I'm doing a momentum curvature usign Popovic's Method and found a big problem beacuse to divide a polygon(convex and concave) into small fiber like this image but with more lines: it's not so easy to do an algorithm. I did a smath file when the polygon it's rectangular but for more general case my smath code doesn't work, I'd like know an algorithm, code or function if it's posible in smath or other language to develop. Best regards. Jesus. Verificacion_de_fluencia_en_acero_fiber_method_degradation_forum.pdf (551kb) downloaded 27 time(s). This might be an application for the GPC wrapper plugin by Davide. gpc1.sm (13kb) downloaded 18 time(s). |
Thank you so much, mkraska and Jean, I'll take a look this package (GPC wrapper).
Jesús.
Ok Jean, I hope You'll find an algorithm to solve that problem.
Best regards Jesus
Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: loha very exciting project! ... algo style to collapse in utilities.
General hatching procedure for arbitrary contours gpc2.sm (43kb) downloaded 22 time(s). |
Joined: 28/08/2014(UTC) Posts: 1,375 Was thanked: 835 time(s) in 529 post(s)
Hi. In the attached, a function for see if a point is inside or outside a polygon, and a code for double integrals using Gauss-Legendre coefficients. InPoly.pdf (98kb) downloaded 20 time(s). InPoly.sm (44kb) downloaded 30 time(s).Best regards. Alvaro.
Wow! Will we be able to calculate the static moment and the moment of inertia of any section with these tools?
gpc3.sm (136kb) downloaded 49 time(s). |
That's superb! Thanks a lot! Has anyone worked on polyhedra, convex hulls and polar polyhedra?
Originally Posted by: loha Has anyone worked on polyhedra, convex hulls and polar polyhedra? I may have something on convex hull Polyhedra, we have C_60 extracted from the adjacency matrix. Jean
anything on the adjacency matrix I am super interested! Handling the adjacency matrix is the only difficulty in fact. Polarity of points-planes is easy.
Originally Posted by: loha anything on the adjacency matrix I am super interested! Handling the adjacency matrix is the only difficulty in fact. Polarity of points-planes is easy. 1. In the attached Buckyball, adjacency matrix is from Mathsoft, Mathsoft borrowed fro Matlab. 2. I have the Mathcad convex hull ORIGIN 0 RemToDo ORIGIN 1 for Smath coding. Cheers ... Jean. Buckyball Adjacency.sm (17kb) downloaded 14 time(s). 0Anim Buckyball.sm (108kb) downloaded 11 time(s). Buckyball.sm (177kb) downloaded 16 time(s).
SMath Studio Forum
Questions
