2 Pages12>
Offline Jesus_Solano
#1 Posted : 29 July 2022 19:13:09(UTC)
Jesus_Solano
Peru
Hi everyone ,I'm doing a momentum curvature usign Popovic's Method and found a big problem beacuse to divide a polygon(convex and concave) into small fiber like this image but with more lines:
General Polygon
it's not so easy to do an algorithm. I did a smath file when the polygon it's rectangular but for more general case my smath code doesn't work, I'd like know an algorithm, code or function if it's posible in smath or other language to develop.
Jesus.
Verificacion_de_fluencia_en_acero_fiber_method_degradation_forum.pdf (551kb) downloaded 25 time(s).
Edited by user 29 July 2022 19:31:21(UTC)  | Reason: Not specified
#2 Posted : 29 July 2022 22:45:52(UTC)
If I understand ...
Your polygon has 9 vertices, we can try a circular spline.
That will add as many points between vertices, is it ?
From there: Area, Perimeter, Center of Gravity.
Give the vertices... Jean.
#3 Posted : 30 July 2022 00:10:04(UTC)
Jesus_Solano
Peru
Hi Jean, exactly I need to known the area, center of gravity and perimeter of the division but the polygon doesn't need to have 9 vertices, this is an example in this case. In general ,I'd like to calculate for n vertices polygon(convex or concave),let me give an example in smath for regular polygon.
polygon_2.sm (37kb) downloaded 8 time(s).
Jesus.
Edited by user 30 July 2022 06:30:45(UTC)  | Reason: Adding and plotting polygon convex and concave
#4 Posted : 30 July 2022 21:49:15(UTC)
Jesus_Solano
Peru
Hi Jean, it was a good solution and you give some ideas to do a code but I'd like to do for more lines and I'd like to optimize the code or algorithm. I did a code in smath maybe need to optimize some parts and get some interesting results, i hope you take a look because a I'd like to aply to convex and no convex polygon, I think it's so hard but I'd like to know the algorithm or code that other programs use. My code doesn't work for some slopes though
Page5 Polygon Copy.sm (117kb) downloaded 10 time(s).
Jesus.
Edited by user 31 July 2022 02:48:47(UTC)  | Reason: correction
Offline mkraska
#5 Posted : 31 July 2022 13:45:01(UTC)
mkraska
General Polygon
Jesus.
This might be an application for the GPC wrapper plugin by Davide.
gpc1.sm (13kb) downloaded 17 time(s).
#6 Posted : 31 July 2022 18:37:52(UTC)
Jesus_Solano
Peru
Thank you so much, mkraska and Jean, I'll take a look this package (GPC wrapper).
Jesús.
#7 Posted : 31 July 2022 22:06:27(UTC)
Jesus_Solano
Peru
Ok Jean, I hope You'll find an algorithm to solve that problem.
Jesus
Offline loha
#8 Posted : 01 August 2022 20:09:35(UTC)
loha
Was thanked: 9 time(s) in 9 post(s)
very exciting project!
#9 Posted : 01 August 2022 20:23:17(UTC)
Jesus_Solano
Peru
Hi Jean it's an excellent solution, thank you so much Clap, I did a code with GPC plugin and I could get this results.
polygon_irregular_fiber_borrador1.sm (35kb) downloaded 15 time(s).
polygon_regular_fiber_borrador1.sm (36kb) downloaded 14 time(s).
Jesus
Edited by user 01 August 2022 21:46:11(UTC)  | Reason: Not specified
#10 Posted : 01 August 2022 21:19:08(UTC)
... algo style to collapse in utilities.
Offline mkraska
#11 Posted : 02 August 2022 01:06:15(UTC)
mkraska
General hatching procedure for arbitrary contours
gpc2.sm (43kb) downloaded 21 time(s).
Offline Razonar
#12 Posted : 02 August 2022 06:05:56(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi. In the attached, a function for see if a point is inside or outside a polygon, and a code for double integrals using Gauss-Legendre coefficients.
InPoly.pdf (98kb) downloaded 18 time(s).
InPoly.sm (44kb) downloaded 28 time(s).
on 02/08/2022(UTC)
Offline loha
#13 Posted : 02 August 2022 08:44:17(UTC)
loha
Wow!
Will we be able to calculate the static moment and the moment of inertia of any section with these tools?
Offline mkraska
#14 Posted : 02 August 2022 12:41:33(UTC)
mkraska
gpc3.sm (136kb) downloaded 48 time(s).
on 02/08/2022(UTC)
Offline loha
#15 Posted : 02 August 2022 15:21:54(UTC)
loha
That's superb!
Clap Clap Clap
Thanks a lot!
Has anyone worked on polyhedra, convex hulls and polar polyhedra?
#16 Posted : 02 August 2022 17:16:59(UTC)
... refreshed for convenience.
Maths Polygon Create.sm (100kb) downloaded 17 time(s).
#17 Posted : 02 August 2022 18:35:53(UTC)
I may have something on convex hull
Polyhedra, we have C_60 extracted from the adjacency matrix.
Offline loha
#18 Posted : 02 August 2022 19:41:40(UTC)
loha
anything on the adjacency matrix I am super interested!
Handling the adjacency matrix is the only difficulty in fact. Polarity of points-planes is easy.
#19 Posted : 03 August 2022 02:47:43(UTC)
1. In the attached Buckyball, adjacency matrix is from Mathsoft,
Mathsoft borrowed fro Matlab.
2. I have the Mathcad convex hull ORIGIN 0
RemToDo ORIGIN 1 for Smath coding.
Buckyball Adjacency.sm (17kb) downloaded 12 time(s).
0Anim Buckyball.sm (108kb) downloaded 10 time(s).
Buckyball.sm (177kb) downloaded 15 time(s).
on 03/08/2022(UTC)
Offline cleisonmanrique
#20 Posted : 24 May 2023 23:25:09(UTC)
cleisonmanrique
Peru
I guess we can not use the same matrix of contour point to get the area and de center of mass ... Or am I wrong ?
2 Pages12>
