Joined: 10/12/2021(UTC) Posts: 6 Was thanked: 1 time(s) in 1 post(s)
Is there any way to present division on the same line and not as a fraction? For example in Mathcad:
If you don't need strictly a division symbol, you can use a multiplication |
Joined: 11/01/2018(UTC) Posts: 133 Location: Wisconsin Was thanked: 61 time(s) in 38 post(s)
Greetings! Originally Posted by: chito ...division on the same line... It is possible to combine Davide's and Jean's solutions, but you need to pull off a few tricks: 1) Create a custom function with (1) parameter 2) Use the special inline division character 「÷」 3) Declare your custom function as a 'unit' (this suppress the multiplication operation from displaying) To create the custom function with the inline division character, copy and paste the following into your SMath Worksheet: To utilize it, type in your numerator and multiply it by the custom function, where you pass the denominator into the function as the parameter. EXAMPLE: solving for 6/2; copy and past e the following (NOTE: since I am declaring the custom function as a unit; you must include ' when calling the custom function): -Kenny Lemens, P.E. Edited by user 17 June 2022 21:38:17(UTC)
| Reason: Spelling Errors (Noted in Orange) |
3 users thanked Kenny Lemens for this useful post.
on 17/06/2022(UTC), on 20/06/2022(UTC), on 21/06/2022(UTC)
Greetings, If you just need the statement to be on the same line and you want to avoid the use of exponents and custom functions, there is a native solution: Use the function str2num(▮) and type your statement as a string: You do have the ability to reference variables, but the use of whitespace (tab, space, newline, etc.) will corrupt the string and str2num(▮) will throw an error. Thus this statement will work: str2num( "(2+22)/4")=6 But this statement will throw a 'not defined' error: str2num( "(2 + 22) / 4")=▮ Its a good day to be alive; -Kenny Lemens, P.E. |
In addition to Kenny you can remove white spaces. Furthermore, you can define a nameless function with Ctrl+Shift+K. It won't show a function before it, though it is a function. By that your statement shall look as a "normal" calculation. Regards str2num.sm (3kb) downloaded 3 time(s).
Originally Posted by: chito Is there any way to present division on the same line and not as a fraction ? Answer is NO, Smath does not have native ÷ operator More productive from infix algo style utilities, for infinite in-situ command line. infix Divide.sm (4kb) downloaded 5 time(s).
Answer is YES, there are multiple ways demonstrated above. Choose what suits you most.
