Offline chito
#1 Posted : 16 December 2021 05:52:35(UTC)
chito
Philippines
Is there any way to present division on the same line and not as a fraction? For example in Mathcad:
#2 Posted : 16 December 2021 14:51:57(UTC)
Originally Posted by: chito Go to Quoted Post
Is there any way to present division on the same line and not as a fraction ?
Maths Infix DIVIDE.sm (5kb) downloaded 11 time(s).
on 16/12/2021(UTC)
#3 Posted : 16 December 2021 16:48:27(UTC)
#4 Posted : 16 December 2021 17:12:28(UTC)
If you don't need strictly a division symbol, you can use a multiplication
Offline Kenny Lemens
#5 Posted : 17 June 2022 21:33:17(UTC)
Kenny Lemens
Was thanked: 61 time(s) in 38 post(s)
Greetings!
...division on the same line...
It is possible to combine Davide's and Jean's solutions, but you need to pull off a few tricks:
   1) Create a custom function with (1) parameter
   2) Use the special inline division character 「÷」
   3) Declare your custom function as a 'unit' (this suppress the multiplication operation from displaying)
To create the custom function with the inline division character, copy and paste the following into your SMath Worksheet:
Code:
'÷(_denom):1/_denom
To utilize it, type in your numerator and multiply it by the custom function, where you pass the denominator into the function as the parameter.
EXAMPLE: solving for 6/2; copy and paste the following (NOTE: since I am declaring the custom function as a unit; you must include ' when calling the custom function):
Code:
6*'÷(2)=#@#
-Kenny Lemens, P.E.
Edited by user 17 June 2022 21:38:17(UTC)  | Reason: Spelling Errors (Noted in Orange)
thanks 3 users thanked Kenny Lemens for this useful post.
on 17/06/2022(UTC),  on 20/06/2022(UTC),  on 21/06/2022(UTC)
#6 Posted : 24 June 2022 23:10:31(UTC)
Kenny Lemens
Greetings,
If you just need the statement to be on the same line and you want to avoid the use of exponents and custom functions, there is a native solution:
Use the function str2num(▮) and type your statement as a string:
You do have the ability to reference variables, but the use of whitespace (tab, space, newline, etc.) will corrupt the string and str2num(▮) will throw an error.
Thus this statement will work:
     str2num("(2+22)/4")=6
But this statement will throw a 'not defined' error:
     str2num("(2 + 22) / 4")=▮
Its a good day to be alive;
-Kenny Lemens, P.E.
Offline overlord
#7 Posted : 25 June 2022 01:12:53(UTC)
Turkey
In addition to Kenny you can remove white spaces.
Furthermore, you can define a nameless function with Ctrl+Shift+K.
It won't show a function before it, though it is a function.
By that your statement shall look as a "normal" calculation.
str2num.sm (3kb) downloaded 3 time(s).
#8 Posted : 25 June 2022 03:55:13(UTC)
Answer is NO, Smath does not have native ÷ operator
More productive from infix algo style utilities,
for infinite in-situ command line.
infix Divide.sm (4kb) downloaded 5 time(s).
Offline overlord
#9 Posted : 25 June 2022 05:12:52(UTC)
Turkey
Answer is YES, there are multiple ways demonstrated above. Choose what suits you most.
#10 Posted : 25 June 2022 20:43:46(UTC)
Guest (2)
