Hello Does anyone know how to change the following units in the matrix shown below?: from "kg/s" to "t/hr", from " kg/{'m*'s^2}" to meters Water Column ("mH2O" , "{'kg*'m^2}/{'s^3}" to Watts.("W" Colebrook_SI_CBG.sm (30kb) downloaded 10 time(s).Best Regards Carlos
Originally Posted by: CBG Hello
Does anyone know how to change the following units in the matrix shown below?: Possibly not with your original result matrix, if you shall use results later. It can be shown in a table region or another pseudo result matrix. Here is the table method.
Here is your matrix with pseudo units. Not very elegant, but it is there.
Hola Carlos. You can use matrix algebra in the unit placeholder. Here one solution. Colebrook_SI_CBG.sm (25kb) downloaded 26 time(s).Best regards. Alvaro.
Originally Posted by: CBG Does anyone know how to change the following units in the matrix shown below?: from "kg/s" to "t/hr", from " kg/{'m*'s^2}" to meters Water Column ("mH2O", "{'kg*'m^2}/{'s^3}" to Watts.("W"
Hola, Carlos Moody as stand alone. Inst_Colebrook MOODY.sm (17kb) downloaded 9 time(s).
Originally Posted by: Jean Giraud Hola, Carlos Moody as stand alone. Relation with what Carlos asked? None, as usual.
Hello
Many thanks to Overlord for his suggestions and solution.
Muchas Gracias tambien a Alvaro por su solucion.
I also thank Jean.
Carlos
Originally Posted by: overlord Relation with what Carlos asked? None, as usual. Project is Colebrook, of which the core algo is Moody. Read Alvaro to learn more.
Originally Posted by: overlord WOW, I feel old. I didn't even remember I was on that forum/website. Thanks for the memory...
Hello, How do I set my units so my answers are in the unit I want, at the moment the answer is being returned to Pa (Pascal) and I would prefer to have the answer in kPa(KiloPascal) or even kN/m^2. I am also getting answers in N(Newtons) and would prefer to have them set to kN (Kilo Newton) rather.
That moment you realize you didn't save a copy of the problem :/ just redid it and realized I have a lot to learn about this program Thanks for the welcome Coversion Problem.sm (27kb) downloaded 9 time(s).
Originally Posted by: Stevan How do I set my units so my answers are in the unit I want? Your attached document is fine. Jean's computer is broken. About your question, there is a placeholder within results. It will appear when you select result. It appears as a black square. You can change your desired result units by altering it. Here is a demonstration how you can do that. Regards
I had a feeling it was going to be something so simple, this is brilliant, thanks!
