Offline CBG
#1 Posted : 24 April 2022 06:34:20(UTC)
CBG
Hello
Does anyone know how to change the following units in the matrix shown below?:
from "kg/s" to "t/hr",
from " kg/{'m*'s^2}" to meters Water Column ("mH2O"Wink,
"{'kg*'m^2}/{'s^3}" to Watts.("W"Wink
Colebrook_SI_CBG.sm (30kb) downloaded 10 time(s).
Carlos
Offline overlord
#2 Posted : 24 April 2022 06:58:52(UTC)
Turkey
Originally Posted by: CBG Go to Quoted Post
Hello
Possibly not with your original result matrix, if you shall use results later.
It can be shown in a table region or another pseudo result matrix.
Here is the table method.
Click to enlarge
Offline overlord
#3 Posted : 24 April 2022 07:46:38(UTC)
Turkey
Here is your matrix with pseudo units.
Not very elegant, but it is there.
Clickto enlarge
Offline Razonar
#4 Posted : 24 April 2022 09:05:54(UTC)
Razonar
Uruguay
Hola Carlos. You can use matrix algebra in the unit placeholder. Here one solution.
Colebrook_SI_CBG.sm (25kb) downloaded 26 time(s).
#5 Posted : 24 April 2022 17:21:48(UTC)
from " kg/{'m*'s^2}" to meters Water Column ("mH2O",
Hola, Carlos
Moody as stand alone.
Convert.PNG Inst_Colebrook MOODY.sm (17kb) downloaded 9 time(s).
Offline overlord
#6 Posted : 24 April 2022 18:59:14(UTC)
Turkey
Hola, Carlos
Relation with what Carlos asked?
None, as usual.
Offline CBG
#7 Posted : 24 April 2022 23:39:01(UTC)
CBG
Hello
Many thanks to Overlord for his suggestions and solution.
Muchas Gracias tambien a Alvaro por su solucion.
I also thank Jean.
Carlos
#8 Posted : 24 April 2022 23:53:16(UTC)
None, as usual.
Project is Colebrook, of which the core algo is Moody.
Read Alvaro to learn more.
Offline overlord
#9 Posted : 25 April 2022 00:08:40(UTC)
Turkey
Reading you in mathcad forums is also instructive.
https://www.eng-tips.com/viewthread.cfm?qid=335795
Offline ElSid
#10 Posted : 02 May 2022 19:24:12(UTC)
ElSid
WOW, I feel old. I didn't even remember I was on that forum/website. Thanks for the memory...
Offline Stevan
#11 Posted : 22 May 2022 15:36:36(UTC)
Stevan
South Africa
How do I set my units so my answers are in the unit I want, at the moment the answer is being returned to Pa (Pascal) and I would prefer to have the answer in kPa(KiloPascal) or even kN/m^2.
I am also getting answers in N(Newtons) and would prefer to have them set to kN (Kilo Newton) rather.
Offline Stevan
#12 Posted : 23 May 2022 20:17:43(UTC)
Stevan
South Africa
That moment you realize you didn't save a copy of the problem :/ just redid it and realized I have a lot to learn about this program Shok
Thanks for the welcome
Coversion Problem.sm (27kb) downloaded 9 time(s).
Offline overlord
#13 Posted : 24 May 2022 00:32:27(UTC)
Turkey
Originally Posted by: Stevan Go to Quoted Post
How do I set my units so my answers are in the unit I want?
Your attached document is fine. Jean's computer is broken.
About your question, there is a placeholder within results.
It will appear when you select result. It appears as a black square.
You can change your desired result units by altering it.
Here is a demonstration how you can do that.
Offline Stevan
#14 Posted : 24 May 2022 02:53:08(UTC)
Stevan
South Africa
I had a feeling it was going to be something so simple, this is brilliant, thanks!
Guest (2)
Similar Topics
wrong unit conversion (psi) (Bugs & Problems)
by gurro 25/01/2020 21:33:10(UTC)
Weird Unit Conversion kg <> ton (Questions)
by ioncube 14/05/2018 11:27:41(UTC)
