2 Pages12>
Offline soletto
#1 Posted : 29 April 2022 11:46:12(UTC)
soletto
Austria
Hallo guys,
i have an simple qeustion:
How can i numerical solve an equation with a solver block like in mathcad.
An equation which is transzentent for example
for example:
sin(x) + x = Y --> solve for x
and how can i solve an equation when equation is not transzentent?
like in mathcad with a solver block area....?
thank you br Stefan
Edited by user 29 April 2022 11:53:14(UTC)  | Reason: Not specified
Offline uni
#2 Posted : 29 April 2022 12:19:37(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
Various examples are possible.
Mathcad Block. FindRoot example.sm (5kb) downloaded 28 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
on 04/05/2022(UTC)
Offline soletto
#3 Posted : 29 April 2022 12:39:29(UTC)
soletto
Austria
ok seems to be that i need some plugins,
where can i find those plugins? I cannot install them directly in the software due to firewall problems thank you!
Offline overlord
#4 Posted : 29 April 2022 13:22:17(UTC)
Turkey
Was thanked: 510 time(s) in 340 post(s)
equation.sm (9kb) downloaded 20 time(s).
on 04/05/2022(UTC)
#5 Posted : 29 April 2022 15:30:23(UTC)
The attached document is minimalist, but most precious for advanced demand.
root is not documented neither available from f(x) menu
but active from Smath/maple companionship.
Observe how powerful for applied maths.
Solve Maple Companion READ FIRST.sm (59kb) downloaded 29 time(s).
Offline alyles
#6 Posted : 29 April 2022 15:42:31(UTC)
alyles
https://smath.info/svn/public/
contains the source. Although if you're behind a firewall you might not be able to access this either.
#7 Posted : 29 April 2022 21:20:31(UTC)
here you have all the gallery plugins, you can download the ones you need and drag&drop those zip archives on your program canvas.
Also, you can create a portable distribution and download/update once you are on another system.
Edited by user 29 April 2022 21:22:31(UTC)  | Reason: Not specified
on 29/04/2022(UTC),  on 04/05/2022(UTC)
Offline soletto
#8 Posted : 03 May 2022 13:25:24(UTC)
soletto
Austria
ok thank you,
@alyles:
some of the plugins i downloaded but the zip file is empty:
for example: Excel Files Plugin --> downloaded but contains no files (maybe firewall delets the content from it...)
Ill use the solve function
another question:
for example if i have a simple equation:
a+b=c
how can i symbolic solve the equation
so that a=c-b is the result.
If i use solve function all variables need to have a number
I simply want to symbolic solve the equation to a variable without using any numbers asigned to a variable
thank you,
br Stefan
Edited by user 03 May 2022 13:49:56(UTC)  | Reason: Not specified
#9 Posted : 03 May 2022 17:04:08(UTC)
Another question:
on 04/05/2022(UTC)
Offline overlord
#10 Posted : 03 May 2022 17:45:50(UTC)
Turkey
There is maple and maxima plugins for symbolic calculations you asked for.
SMath's own symbolic engine is not capable as those two.
Offline soletto
#11 Posted : 03 May 2022 21:35:45(UTC)
soletto
Austria
thank you,
can you provide me with the smath file so that i can look into? Thank you br Stefan
Offline overlord
#12 Posted : 03 May 2022 21:53:56(UTC)
Turkey
thank you,
Notice the optimizations are set to symbolic to view results.
You can check and set optimization of individual regions by right click.
symbolic.sm (5kb) downloaded 35 time(s).
Offline soletto
#13 Posted : 04 May 2022 12:14:37(UTC)
soletto
Austria
Thank you but i have a problem i downloaded the latest version
i downloaded maxima plugin and others but i do get a failure when opening your file see attached picture
There is a file missing:
cmaple.exe / maxima.bat missing
What can i do ?
however smath says maxima plugin is installed:
Thank you br Stefan
Edited by user 04 May 2022 12:19:49(UTC)  | Reason: Not specified
Offline overlord
#14 Posted : 04 May 2022 12:42:10(UTC)
Turkey
What can i do ?
Thank you br Stefan
It seems your mentioned firewall settings prevented proper installation of Maple plugin.
Usually SMath plugins are saved under this path in Windows 10.
C:\Users\<username>/AppData/Roaming/SMath/extensions/plugins/
I can copy my plugins directory on Windows partition and upload it for you to download and copy/overwrite.
But it won't be a convenient way to install plugins. Set an exception to your firewall for SMath downloads.
Maxima is another subject, plugin seems installed but you will need Maxima software to make it work.
Latest version can be downloaded and installed from link below.
https://netix.dl.sourceforge.net/project/maxima/Maxima-Windows/5.46.0-Windows/maxima-5.46.0-win64.exe
You also have to set the path for Maxima.bat under Insert>Maxima control windows>Settings menu.
Click to enlarge
on 04/05/2022(UTC)
Offline soletto
#15 Posted : 04 May 2022 12:47:03(UTC)
soletto
Austria
o ok
i need maxima software in order to work properly?
I was thinking the plugin only is enough?
Thank you for the input!
Yes please upload your plugins folder since i cannot download the plugins in the software due to firewall
But what plugin is there required under bin "cmaple.exe"
What he cannot find?
Edited by user 04 May 2022 12:58:01(UTC)  | Reason: Not specified
Offline overlord
#16 Posted : 04 May 2022 13:10:30(UTC)
Turkey
It may have not all plugins, it is just copy of my personal folder.
plugins.zip
on 04/05/2022(UTC)
Offline soletto
#17 Posted : 04 May 2022 13:32:35(UTC)
soletto
Austria
another question:
what is the name of the maple plugin you mentioned?
I may need maple software in order to work properly i think or?
Thank you br Stefan
Offline overlord
#18 Posted : 04 May 2022 13:41:01(UTC)
Turkey
another question:
Thank you br Stefan
You won't need additional software installation with maple plugin.
on 04/05/2022(UTC)
Offline soletto
#19 Posted : 04 May 2022 13:54:19(UTC)
soletto
Austria
ok thank you but now im a little bit confused.
I searched maple plugin herer:
https://en.smath.com/list/plugins
but i cannot find the plugin
software needs cmaple.exe in order to work. Where do i find this?
Thank you br Stefan
Edited by user 04 May 2022 13:58:10(UTC)  | Reason: Not specified
Offline overlord
#20 Posted : 04 May 2022 14:10:28(UTC)
Turkey
https://smath.info:8443/!/#public/view/head/plugins/MapleTools/Resources
It is in cmaple.zip file on this page.
It is in also plugin.zip file I uploaded for you.
on 04/05/2022(UTC)
Similar Topics
How to solve an equation for multiple values of the independent var. (Questions)
by mangurian 22/09/2019 17:04:24(UTC)
2 Pages12>
