Hallo guys, i have an simple qeustion: How can i numerical solve an equation with a solver block like in mathcad. An equation which is transzentent for example for example: sin(x) + x = Y --> solve for x and how can i solve an equation when equation is not transzentent? like in mathcad with a solver block area....? thank you br Stefan Edited by user 29 April 2022 11:53:14(UTC)
| Reason: Not specified
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,495 Was thanked: 1275 time(s) in 746 post(s)
ok seems to be that i need some plugins,
where can i find those plugins? I cannot install them directly in the software due to firewall problems thank you!
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Originally Posted by: soletto how can i solve an equation when equation is not transzentent? The attached document is minimalist, but most precious for advanced demand. root is not documented neither available from f(x) menu but active from Smath/maple companionship. Observe how powerful for applied maths. Cheers ... Jean. Solve Maple Companion READ FIRST.sm (59kb) downloaded 29 time(s).
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
Originally Posted by: soletto ok seems to be that i need some plugins,
where can i find those plugins? I cannot install them directly in the software due to firewall problems thank you! https://smath.info/svn/public/contains the source. Although if you're behind a firewall you might not be able to access this either. |
here you have all the gallery plugins, you can download the ones you need and drag&drop those zip archives on your program canvas. Also, you can create a portable distribution and download/update once you are on another system. Edited by user 29 April 2022 21:22:31(UTC)
on 29/04/2022(UTC), on 04/05/2022(UTC)
ok thank you, @alyles: some of the plugins i downloaded but the zip file is empty: for example: Excel Files Plugin --> downloaded but contains no files (maybe firewall delets the content from it...) Ill use the solve function another question: for example if i have a simple equation: a+b=c how can i symbolic solve the equation so that a=c-b is the result. If i use solve function all variables need to have a number I simply want to symbolic solve the equation to a variable without using any numbers asigned to a variable thank you, br Stefan Edited by user 03 May 2022 13:49:56(UTC)
Originally Posted by: soletto Another question:
There is maple and maxima plugins for symbolic calculations you asked for. SMath's own symbolic engine is not capable as those two. Regards
thank you,
can you provide me with the smath file so that i can look into? Thank you br Stefan
Originally Posted by: soletto thank you,
can you provide me with the smath file so that i can look into? Thank you br Stefan Notice the optimizations are set to symbolic to view results. You can check and set optimization of individual regions by right click. Regards symbolic.sm (5kb) downloaded 35 time(s).
Thank you but i have a problem i downloaded the latest version i downloaded maxima plugin and others but i do get a failure when opening your file see attached picture There is a file missing: cmaple.exe / maxima.bat missing What can i do ? however smath says maxima plugin is installed: Thank you br Stefan Edited by user 04 May 2022 12:19:49(UTC)
Originally Posted by: soletto Thank you but i have a problem i downloaded the latest version
What can i do ?
Thank you br Stefan It seems your mentioned firewall settings prevented proper installation of Maple plugin. Usually SMath plugins are saved under this path in Windows 10. C:\Users\<username>/AppData/Roaming/SMath/extensions/plugins/I can copy my plugins directory on Windows partition and upload it for you to download and copy/overwrite. But it won't be a convenient way to install plugins. Set an exception to your firewall for SMath downloads. -- Maxima is another subject, plugin seems installed but you will need Maxima software to make it work. Latest version can be downloaded and installed from link below. https://netix.dl.sourceforge.net/project/maxima/Maxima-Windows/5.46.0-Windows/maxima-5.46.0-win64.exeYou also have to set the path for Maxima.bat under Insert>Maxima control windows>Settings menu. Regards
o ok i need maxima software in order to work properly? I was thinking the plugin only is enough? Thank you for the input! Yes please upload your plugins folder since i cannot download the plugins in the software due to firewall But what plugin is there required under bin "cmaple.exe" What he cannot find? Edited by user 04 May 2022 12:58:01(UTC)
Originally Posted by: soletto Yes please upload your plugins folder since i cannot download the plugins in the software due to firewall It may have not all plugins, it is just copy of my personal folder. plugins.zip
another question:
what is the name of the maple plugin you mentioned?
I may need maple software in order to work properly i think or?
Thank you br Stefan
Thank you br Stefan You won't need additional software installation with maple plugin.
ok thank you but now im a little bit confused. I searched maple plugin herer: https://en.smath.com/list/pluginsbut i cannot find the plugin software needs cmaple.exe in order to work. Where do i find this? Thank you br Stefan Edited by user 04 May 2022 13:58:10(UTC)
