Offline Darcy
#1 Posted : 25 April 2022 10:13:57(UTC)
Darcy
Australia
Hi all,
I am trying to solve for an unknown variable on Smath, a very straight forward operation on my calculator, however I'm trying to figure out how to display it on an Smath work sheet. Thanks in advance for your help. I am currently just using the solve function, inputting the function with the undefined parameter, A.st, and using tthe booleen operator to allow for calculation and it is saying no real roots...
Offline overlord
#2 Posted : 25 April 2022 14:15:43(UTC)
Turkey
Was thanked: 290 time(s) in 204 post(s)
Click to enlarge
solve_roots.sm (13kb) downloaded 8 time(s).
Edited by user 25 April 2022 21:42:23(UTC)  | Reason: Not specified
Online uni
#3 Posted : 25 April 2022 14:22:41(UTC)
uni
Was thanked: 1163 time(s) in 672 post(s)
This works too: al_nleqsolve(guess,f)
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Darcy
#4 Posted : 25 April 2022 15:11:57(UTC)
Darcy
Australia
Thankyou for your reply, if possible could you explain what you mean, i will upload a smath file of the sheet i am working on, if you could have a look, it would be greatly appreciatd!
Offline Darcy
#5 Posted : 25 April 2022 15:13:04(UTC)
Darcy
Australia
ASSINGMENT_1.sm (921kb) downloaded 12 time(s).
Cheers Guys!!
Offline overlord
#6 Posted : 25 April 2022 16:17:41(UTC)
Turkey
Here is your file solved with various solvers.
I also corrected your formula depending on your first question.
d.eff is multiplied in your file, subtraction occurs at first post.
solve() can solve between -20,20 range as default.
If your result shall be out of this bound, you will need to specify it.
Or you can change your default roots range from Tools>Options>Calculations.
FindRoot() can also solve equations with units as maple-solve.
Just give it a boolean guess to start calculation with.
Be careful, it will assign your unknown with result.
ASSINGMENT_1_result.sm (1,015kb) downloaded 15 time(s).
Edited by user 25 April 2022 17:05:08(UTC)  | Reason: Not specified
on 25/04/2022(UTC)
Offline overlord
#7 Posted : 25 April 2022 20:19:15(UTC)
Turkey
You can also solve your problem with quadratic formula.
And here is your one-line algebraic solution.
It is derived from quadratic formula.
Numeric solvers not involved.
Edited by user 26 April 2022 02:46:12(UTC)  | Reason: Not specified
Offline Darcy
#8 Posted : 26 April 2022 04:23:29(UTC)
Darcy
Australia
Thankyou all so much,
very mush appreciated!
#9 Posted : 26 April 2022 21:26:53(UTC)
Was thanked: 910 time(s) in 738 post(s)
As given, the duplicate solution is unique wrt the given project variables.
By ranging wisely, you can recursively solve wrt any of the variables involved.
From there, enrich the project document by adding plot(s).
Offline overlord
#10 Posted : 26 April 2022 22:11:11(UTC)
Turkey
Feel free to ask anything.
Near all users will try to help you for your questions.
