SMath Studio Forum
Bugs & Problems
Solving for Undefined variables, no real roots error
Hi all, I am trying to solve for an unknown variable on Smath, a very straight forward operation on my calculator, however I'm trying to figure out how to display it on an Smath work sheet. Thanks in advance for your help. I am currently just using the solve function, inputting the function with the undefined parameter, A.st, and using tthe booleen operator to allow for calculation and it is saying no real roots...
Joined: 23/07/2013(UTC) Posts: 1,126 Was thanked: 507 time(s) in 338 post(s)
This works too: al_nleqsolve(guess,f) |
Thankyou for your reply, if possible could you explain what you mean, i will upload a smath file of the sheet i am working on, if you could have a look, it would be greatly appreciatd!
Here is your file solved with various solvers. I also corrected your formula depending on your first question. d.eff is multiplied in your file, subtraction occurs at first post. solve() can solve between -20,20 range as default. If your result shall be out of this bound, you will need to specify it. Or you can change your default roots range from Tools>Options>Calculations. FindRoot() can also solve equations with units as maple-solve. Just give it a boolean guess to start calculation with. Be careful, it will assign your unknown with result. Regards ASSINGMENT_1_result.sm (1,015kb) downloaded 22 time(s).Edited by user 25 April 2022 17:05:08(UTC)
| Reason: Not specified
You can also solve your problem with quadratic formula. Regards And here is your one-line algebraic solution. It is derived from quadratic formula. Numeric solvers not involved. Edited by user 26 April 2022 02:46:12(UTC)
Thankyou all so much, very mush appreciated!
As given, the duplicate solution is unique wrt the given project variables. By ranging wisely, you can recursively solve wrt any of the variables involved. From there, enrich the project document by adding plot(s). Cheers ... Jean.
Originally Posted by: Darcy Thankyou all so much, very mush appreciated! Feel free to ask anything. Near all users will try to help you for your questions.
SMath Studio Forum
Bugs & Problems
