Offline TIAGO_ENG2012
#1 Posted : 06 January 2022 00:03:42(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma.
my input data is hprofundidade1 z w and y
TESTE TENSAO ADM MATRIZ.sm (6kb) downloaded 9 time(s).
Edited by user 06 January 2022 00:39:18(UTC)  | Reason: Not specified
Offline overlord
#2 Posted : 06 January 2022 07:50:51(UTC)
Turkey
I didn't understand what to calculate in sigma function.
A little more explanation would help to resolve it.
TESTE TENSAO ADM MATRIZ_r1.sm (9kb) downloaded 9 time(s).
#3 Posted : 06 January 2022 13:57:04(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
I don't understand the problem, only to get a plot.
Good morning,
I reworded the file with an SPT matrix, my goal is to loop to find the value of sigma h in the depth that I inform in the input I am attaching a photo of what the final result should look like with the graph
TESTE TENSAO ADM MATRIZ.sm (14kb) downloaded 14 time(s).
Offline Razonar
#4 Posted : 06 January 2022 21:04:40(UTC)
Razonar
Uruguay
Hi. I think that this could be the solution.
TESTE TENSAO ADM MATRIZ.sm (6kb) downloaded 8 time(s).
Offline overlord
#5 Posted : 06 January 2022 22:49:36(UTC)
Turkey
I still don't understand purpose of for() loops. (not in your solution, original question)
Removing for()'s and calculating directly won't change the result.
Offline Razonar
#6 Posted : 07 January 2022 01:06:33(UTC)
Razonar
Uruguay
Hi overlord. I guess because using γ.s2(h)*h isn't correct, there the correct acumulation is γ.s2(h)*Δh
TESTE TENSAO ADM MATRIZ.sm (11kb) downloaded 10 time(s).
Edited by user 07 January 2022 01:35:52(UTC)  | Reason: Added some coefiente of empuxo k(h)
#7 Posted : 07 January 2022 14:51:39(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
Good morning,
thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
see the resolution of the problem in the attached image
#8 Posted : 07 January 2022 17:23:15(UTC)
TIAGO_ENG2012
Rank: Member
Brazil
At this point, up to You to handle the project.
I understood nothing in that big image.
TESTE TENSAO ADM MATRIZ (in_situ parametric).sm (19kb) downloaded 6 time(s).
PERFECT FELL LIKE A GLOVE is there a way to rotate the result of the graph 90 degrees?
Offline Razonar
#9 Posted : 07 January 2022 22:01:35(UTC)
Razonar
Uruguay
...some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Hi. You can try to change the input values by yourself.
Offline Razonar
#10 Posted : 07 January 2022 23:44:30(UTC)
Razonar
Uruguay
This is a way to do that in SMath.
TESTE TENSAO ADM MATRIZ v2.sm (456kb) downloaded 17 time(s).
Edited by user 08 January 2022 00:13:47(UTC)  | Reason: Not specified
#11 Posted : 08 January 2022 17:14:01(UTC)
... updated from Alvaro latest addition.
Cleaned image(s) for publishing the traced reference.
You can have as many sets of parameters [p,d] as you wish,
even of different length as long as you update respectively.
Project Algo_Parameters.sm (662kb) downloaded 6 time(s).
I guess the last 4 'x' points [18,19,20,21] should be removed.
Offline overlord
#12 Posted : 08 January 2022 20:36:52(UTC)
Turkey
Razonar's post has answer already. Jean's post is a re-post.
No reason to re-post same file with some enigmatic, non-related, preceded functions.
TESTE TENSAO ADM MATRIZ v2.sm (456kb) downloaded 17 time(s). <--- Razonar's post
Project Algo_Parameters.sm (662kb) downloaded 6 time(s). <--- Jean's shameless repost (don't download this)
#13 Posted : 08 January 2022 22:45:12(UTC)
Offered as demanded in two separate parts in same document.
Thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Project Algo_Parameters Copy.sm (664kb) downloaded 6 time(s).
Offline overlord
#14 Posted : 09 January 2022 00:28:58(UTC)
Turkey
I am pretty sure topic owner didn't request from someone to re-post one anothers sample.
thanks 2 users thanked overlord for this useful post.
on 09/01/2022(UTC),  on 09/01/2022(UTC)
Guest (2)
