SMath Studio Forum
Questions
how to apply a conditional to an interval
Joined: 09/12/2021(UTC) Posts: 27 Location: MG Was thanked: 1 time(s) in 1 post(s)
Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma. my input data is hprofundidade1 z w and y TESTE TENSAO ADM MATRIZ.sm (6kb) downloaded 9 time(s).Edited by user 06 January 2022 00:39:18(UTC)
| Reason: Not specified
Originally Posted by: TIAGO_ENG2012 Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma.
my input data is hprofundidade1 z w and y I didn't understand what to calculate in sigma function. A little more explanation would help to resolve it. Regards TESTE TENSAO ADM MATRIZ_r1.sm (9kb) downloaded 9 time(s).
Originally Posted by: Jean Giraud Originally Posted by: TIAGO_ENG2012 Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma.
my input data is hprofundidade1 z w and y I don't understand the problem, only to get a plot. Good morning, I reworded the file with an SPT matrix, my goal is to loop to find the value of sigma h in the depth that I inform in the input I am attaching a photo of what the final result should look like with the graph 1641462442629.jpg (5,534kb) downloaded 17 time(s). TESTE TENSAO ADM MATRIZ.sm (14kb) downloaded 14 time(s).
Originally Posted by: Razonar Hi. I think that this could be the solution. I still don't understand purpose of for() loops. (not in your solution, original question) Removing for()'s and calculating directly won't change the result.
Originally Posted by: overlord Originally Posted by: Razonar Hi. I think that this could be the solution. I still don't understand purpose of for() loops. (not in your solution, original question) Removing for()'s and calculating directly won't change the result. Hi overlord. I guess because using γ.s2(h)*h isn't correct, there the correct acumulation is γ.s2(h)* Δh TESTE TENSAO ADM MATRIZ.sm (11kb) downloaded 10 time(s).Best regards. Alvaro. Edited by user 07 January 2022 01:35:52(UTC)
| Reason: Added some coefiente of empuxo k(h)
Good morning, thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth. see the resolution of the problem in the attached image 1641462442620.jpg (4,028kb) downloaded 13 time(s).
Originally Posted by: Jean Giraud Originally Posted by: TIAGO_ENG2012 thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth. At this point, up to You to handle the project. I understood nothing in that big image. TESTE TENSAO ADM MATRIZ (in_situ parametric).sm (19kb) downloaded 6 time(s). PERFECT FELL LIKE A GLOVE is there a way to rotate the result of the graph 90 degrees?
Originally Posted by: TIAGO_ENG2012 ...some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth. ... Hi. You can try to change the input values by yourself. Best regards. Alvaro.
Originally Posted by: TIAGO_ENG2012 ... see the resolution of the problem in the attached image 1641462442620.jpg (4,028kb) downloaded 13 time(s). This is a way to do that in SMath. TESTE TENSAO ADM MATRIZ v2.sm (456kb) downloaded 17 time(s).Best regards. Alvaro. Edited by user 08 January 2022 00:13:47(UTC)
... updated from Alvaro latest addition. Cleaned image(s) for publishing the traced reference. You can have as many sets of parameters [p,d] as you wish, even of different length as long as you update respectively. Cheers ... Jean. Project Algo_Parameters.sm (662kb) downloaded 6 time(s).I guess the last 4 'x' points [18,19,20,21] should be removed.
Razonar's post has answer already. Jean's post is a re-post. No reason to re-post same file with some enigmatic, non-related, preceded functions. TESTE TENSAO ADM MATRIZ v2.sm (456kb) downloaded 17 time(s). <--- Razonar's post Project Algo_Parameters.sm (662kb) downloaded 6 time(s). <--- Jean's shameless repost ( don't download this)
Originally Posted by: overlord (don't download this) Offered as demanded in two separate parts in same document. Thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth. see the resolution of the problem in the attached image Project Algo_Parameters Copy.sm (664kb) downloaded 6 time(s).
I am pretty sure topic owner didn't request from someone to re-post one anothers sample.
2 users thanked overlord for this useful post.
on 09/01/2022(UTC), on 09/01/2022(UTC)
SMath Studio Forum
Questions
