a very simply question. unlike Matlab Mathtype the "for loop" is quit strange. The result should be that the statements s+jj are executed 100 times, jj is incresed by 1.0 each time Finally, s is the sum, and the result should be a number such as 5050. I use this example to verify the execution of the for loop so what is wrong with it ? forloop.sm (4kb) downloaded 20 time(s).Edited by user 10 September 2021 08:44:43(UTC)
| Reason: Not specified
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
Fine here too, no problems. Is the Auto calculation enabled?
Originally Posted by: wty3000 a very simply question. unlike Matlab Mathtype the "for loop" is quit strange. The result should be that the statements s+jj are executed 100 times, jj is incresed by 1.0 each time Finally, s is the sum, and the result should be a number such as 5050. I use this example to verify the execution of the for loop so what is wrong with it ? forloop.sm (4kb) downloaded 20 time(s). after the software restarted, the for loop is OK thanks Edited by moderator 15 September 2021 15:29:18(UTC)
| Reason: marked as SOLVED
Originally Posted by: wty3000 after the software restarted, the for loop is OK
thanks So it was "four engineer joke" again.
