Hello, I bumped into roots() problem again - SMath 0.93 Here is the file - Primer43.sm. Or a slight modification - Primer43a.smIt's been again solved by Newton-Raphson - linear problem, but roots() failed. In WinXP if you try to get the results by roots() - crash will happen. In Ubuntu - stack overflow error will be issued. Regards, Radovan Edited by user 29 March 2012 00:09:54(UTC)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,651 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
omorr wrote:Hello, I bumped into roots() problem again - SMath 0.93 Here is the file - Primer43.sm. It's been again solved by Newton-Raphson - linear problem, but roots() failed. In WinXP if you try to get the results by roots() crash will happen [...] In Ubuntu - stack overflow error will be issued [...] Regards, Radovan Same problem with Win 7 |
Hello Andrey, Here is another similar example Primer44.sm . SMath will crash with roots() again. Fortunately, Newton-Raphson will do the job. Regards, Radovan |
Hello Andrey, Here is another example Primer46.smThis time there is no roots() involved. Crash will happen (stack overflow in Ubuntu) if the optimization of the region calculating X is Symbolical. If we set the Numerical optimization everything is fine. Regards, Radovan |
Ok. Will check all these examples.
Regards.
Hello Andrey, I was pleasantly surprised that roots() worked in my example Pimer44.sm Primer44OK.smPrimer43.sm and Primer43a.sm did not cause stack overflow but only "No real roots" message. Not quite sure why because those problems are similar. Primer46.sm still crashes with Symbolic optimization. I think it is an improvement of roots() in 0.94 regarding these examples. Thank you for your efforts. Regards, Radovan |
Hello, Originally Posted by: omorr Primer46.sm still crashes with Symbolic optimization.
Unfortunately, It happened in v0.95 as well. I changed this file a bit, regarding the change in stack() function in order to get a function for which Jacobian can be found. It looks quite innocent - but still crashes for symbolic optimization . Here is the end of this file: and now when enabling calculation of the last region The Jacobian matrix J is problematic here. If you use Symbolic optimization of J inverse - crash will happen. Here is the file: Primer46-crash-nostack-Ok.smWhy this causes the crash - have no idea. Could someone read this file and check it out, please? Regards, Radovan |
Hi omorr, I can see the same issue, but I've no ideas about origins (could be the symbolic evaluation of submatrix()?) regards, w3b5urf3r Edited by user 18 September 2012 01:36:36(UTC)
Thanks for answering w3b5urf3r, Originally Posted by: w3b5urf3r_reloaded I can see the same issue, but I've no ideas about origins (could be the symbolic evalutation of submatrix()?) It seems submatrix() is not the reason. I have another example where roots() will work - although the function is defined with submatrix() and the Jacobian is not with all constants (nonlinear equations): Here is the file: Primer47-Ok-1.sm. I do not know what is the reason of this, but SMath should not crash anyway. Regards, Radovan |
if may be useful, in this file ( 0.95_Jacob_symbolic.sm.zip), I've minimized all possible crash causes (lines(), for loops, etc...) I think that this could reduce the issue options (mathematical problem or code problem with Jacob()<->symbolic evaluation)... regards, w3b5urf3r Edited by user 18 September 2012 01:37:34(UTC)
Thank you w3b5urf3rYou gave me again the idea where to "poke" about this. It seems there is nothing to do with Jacob or anything else (lines(), for loops, etc...). It is about this particular matrix and numbers in it. Just put this matrix with particular numbers in an empty sheet and again crash will happen. Here is the file : strange matrix crash.smJust put some other numbers and choose Symbolic for, say, J/J and crash will happen again. Put some other numbers and crash will not happen. Very strange Regards, radovan Edited by user 19 June 2012 21:11:49(UTC)
Originally Posted by: omorr Just put some other numbers and choose Symbolic for, say, J/J and crash will happen again. Put some other numbers and crash will not happen. Very strange really very strange, thus the problem it's the inversion but not for any matrix... in any case Jacob() seems to work fine regards, w3b5urf3r |
