Offline omorr
#1 Posted : 28 March 2012 23:51:04(UTC)
omorr
Serbia
I bumped into roots() problem again - SMath 0.93
Here is the file - Primer43.sm.
Or a slight modification - Primer43a.sm
It's been again solved by Newton-Raphson - linear problem, but roots() failed.
In WinXP if you try to get the results by roots() - crash will happen.
In Ubuntu - stack overflow error will be issued.
Edited by user 29 March 2012 00:09:54(UTC)  | Reason: Not specified
#2 Posted : 28 March 2012 23:56:03(UTC)
Was thanked: 1339 time(s) in 878 post(s)
In WinXP if you try to get the results by roots() crash will happen
Same problem with Win 7
Offline Andrey Ivashov
#3 Posted : 30 March 2012 07:43:08(UTC)
Thank you. Will fix it.
on 30/03/2012(UTC)
Offline omorr
#4 Posted : 31 March 2012 07:56:02(UTC)
omorr
Serbia
Hello Andrey,
Here is another similar example Primer44.sm . SMath will crash with roots() again.
Fortunately, Newton-Raphson will do the job.
Offline omorr
#5 Posted : 31 March 2012 21:29:27(UTC)
omorr
Serbia
Hello Andrey,
Here is another example Primer46.sm
This time there is no roots() involved.
Crash will happen (stack overflow in Ubuntu) if the optimization of the region calculating X is Symbolical. If we set the Numerical optimization everything is fine.
#6 Posted : 31 March 2012 22:07:15(UTC)
Ok. Will check all these examples.
Regards.
Offline omorr
#7 Posted : 19 May 2012 22:24:45(UTC)
omorr
Serbia
Hello Andrey,
I was pleasantly surprised that roots() worked in my example Pimer44.sm Good
roots() working
Primer44OK.sm
Primer43.sm and Primer43a.sm did not cause stack overflow but only "No real roots" message. Not quite sure why because those problems are similar.
Primer46.sm still crashes with Symbolic optimization.
I think it is an improvement of roots() in 0.94 regarding these examples. Thank you for your efforts.
Offline omorr
#8 Posted : 19 June 2012 13:13:31(UTC)
omorr
Serbia
Unfortunately, It happened in v0.95 as well. I changed this file a bit, regarding the change in stack() function in order to get a function for which Jacobian can be found. It looks quite innocent - but still crashes for symbolic optimization .
Here is the end of this file:
Primer46-crash-nostack-Ok-1
and now when enabling calculation of the last region
Primer46-crash-nostack-Ok-2
The Jacobian matrix J is problematic here. If you use Symbolic optimization of J inverse - crash will happen.
Primer46-crash-nostack-Ok-3
Here is the file: Primer46-crash-nostack-Ok.sm
Why this causes the crash - have no idea. Could someone read this file and check it out, please?
#9 Posted : 19 June 2012 14:52:35(UTC)
Hi omorr,
I can see the same issue, but I've no ideas about origins (could be the symbolic evaluation of submatrix()?)
regards,
w3b5urf3r
Edited by user 18 September 2012 01:36:36(UTC)  | Reason: Not specified
on 19/06/2012(UTC)
Offline omorr
#10 Posted : 19 June 2012 15:56:41(UTC)
omorr
Serbia
Thanks for answering w3b5urf3r,
Originally Posted by: w3b5urf3r_reloaded Go to Quoted Post
I can see the same issue, but I've no ideas about origins (could be the symbolic evalutation of submatrix()?)
It seems submatrix() is not the reason. I have another example where roots() will work Good - although the function is defined with submatrix() and the Jacobian is not with all constants (nonlinear equations):
Primer47-Ok-1
Here is the file: Primer47-Ok-1.sm.
I do not know what is the reason of this, but SMath should not crash anyway.
#11 Posted : 19 June 2012 20:09:41(UTC)
if may be useful, in this file (0.95_Jacob_symbolic.sm.zip), I've minimized all possible crash causes (lines(), for loops, etc...)
I think that this could reduce the issue options (mathematical problem or code problem with Jacob()<->symbolic evaluation)...
Jacob() issue
regards,
w3b5urf3r
Edited by user 18 September 2012 01:37:34(UTC)  | Reason: Not specified
on 19/06/2012(UTC)
Offline omorr
#12 Posted : 19 June 2012 21:08:04(UTC)
omorr
Serbia
Thank you w3b5urf3r
You gave me again the idea where to "poke" about this. It seems there is nothing to do with Jacob or anything else (lines(), for loops, etc...). It is about this particular matrix and numbers in it. Just put this matrix with particular numbers in an empty sheet and again crash will happen.
Here is the file : strange matrix crash.sm
Just put some other numbers and choose Symbolic for, say, J/J and crash will happen again. Put some other numbers and crash will not happen.
Very strange Shok
radovan
Edited by user 19 June 2012 21:11:49(UTC)  | Reason: Not specified
on 20/06/2012(UTC)
#13 Posted : 20 June 2012 01:01:40(UTC)
Very strange Shok
really very strange, thus the problem it's the inversion but not for any matrix...
in any case Jacob() seems to work fine Happy
regards,
w3b5urf3r
