Joined: 05/03/2012(UTC) Posts: 3 Location: South Africa
Hi, I have found that in versions 0.92 and 0.93 there is a problem with specifying units for an answer. In 0.91 it would simply show that there was a syntax error by borering the specific block RED. The error is when multiple units are combined to for other units for example torque (Nm) or acceleration (m/s^2). If one of the fieldsis left blank then 0.92 and 0.93 crash. in 0.91 1*'N*1*'m=#@'N* in 0.93 1*'N*1*'m=#@'N* 1*'N*'m=#@#*# I know this seems like a small problem, but it causes me huge pain when do long calculations and lots of work is lost due to a typo! It appears that a # may not be generateing in the code to indicate a no value entity. Thanks for the help Edited by moderator 08 March 2012 10:17:53(UTC)
| Reason: Not specified
Sorry should read Hi, I have found that in versions 0.92 and 0.93 there is a problem with specifying units for an answer. In 0.91 it would simply show that there was a syntax error by borering the specific block RED. The error is when multiple units are combined to for other units for example torque (Nm) or acceleration (m/s^2). If one of the fieldsis left blank then 0.92 and 0.93 crash. in 0.91 in 0.93 Code:1*'N*1*'m=#@'N*
1*'N*'m=#@#*#
Hello, I did not understand quite well, sorry - but I think I can reproduce the crash. See the picture please: When you just type in the rightmost placeholder (used for changing units), say *N and press enter, the crash occurred. This is a typo, but should not be causing a crash. Regards, Radovan |
Thanks Radovan,
Sorry for the bad explanation (trying to get the hang of this forum), but you have repreduced what i have a problem with exactly.
It is not major, just annoying as explained.
Bamo
Thank you! Fixed.
Regards.
