Offline Yes Man
#1 Posted : 13 March 2020 21:27:06(UTC)
Yes Man
Hi everyone, I've got problem with while loop. I have this function with Xstart = 0.2 ; Xfinish = 2 ; deltaX = 0.2 and I need to solve it in smath studio, but while loop is processing forever and never ends. I'm doing something wrong, or it's a bug? Thanks!
Images:
https://postimg.cc/Q9mqWkKd Smath studio
https://postimg.cc/KKZkgXPt Function I need to solve
Edited by user 14 March 2020 16:35:01(UTC)  | Reason: Not specified
Offline ndtma
#2 Posted : 13 March 2020 22:58:44(UTC)
ndtma
Sri Lanka
Was thanked: 125 time(s) in 82 post(s)
Is this what you need?
Edited by user 13 March 2020 23:01:26(UTC)  | Reason: Not specified
Offline Yes Man
#3 Posted : 13 March 2020 23:14:41(UTC)
Yes Man
No, I need a range of numbers for X and Y, like: First X = 0.2, it's calculating Y(0.2) and shows first Y result, then X = 0.4 (previous X + delta X) and it's calculating Y(0.4), and until x = 2. In final I need a range of all X and all Y results.
#4 Posted : 13 March 2020 23:30:47(UTC)
Some examples ...
Utilities Pts Critical Monte-Carlo.sm (19kb) downloaded 12 time(s).
Utilities Program While FindIndex.sm (35kb) downloaded 21 time(s).
Offline Yes Man
#5 Posted : 13 March 2020 23:55:24(UTC)
Yes Man
Some examples ...
I'm not sure I understood how to solve my function by this examples.
I don't know what I'm doing wrong:
#6 Posted : 14 March 2020 02:38:39(UTC)
Your proposal is not a case of while loop,
strictly wrong application.
Page44 Unknown.sm (74kb) downloaded 10 time(s).
Offline mkraska
#7 Posted : 14 March 2020 12:06:47(UTC)
mkraska
You can do the job using a while loop but it is just one option (perhaps not the most straightforward one).
loops.sm (11kb) downloaded 14 time(s).
Edited by user 14 March 2020 12:10:02(UTC)  | Reason: Not specified
thanks 3 users thanked mkraska for this useful post.
on 14/03/2020(UTC),  on 14/03/2020(UTC),  on 14/03/2020(UTC)
Offline Yes Man
#8 Posted : 14 March 2020 12:19:48(UTC)
Yes Man
I need all X and all Y(x) values in the end, for Xfirst = 0.2, Xlast = 2 with step 0.2.
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
And it should look something like this:
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
I can type every y(x) in smath studio:
https://postimg.cc/0bddLTqF
But, is it possible to do it with while loop?
Offline Yes Man
#9 Posted : 14 March 2020 12:21:13(UTC)
Yes Man
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
#10 Posted : 14 March 2020 14:25:47(UTC)
What you are asking for is so restricted and useless for purpose !
Then you can:
1. start wherever [L] as long as computable your ln(,)
2. end wherever [N]
3. as fine step size [Δ]
4. algo style for infinite applications
Offline Yes Man
#11 Posted : 14 March 2020 14:52:29(UTC)
Yes Man
Then you can:
2. end wherever [N]
I'm asking for this cos' we are learning Pascal programming language in university, and we need to write this function in Pascal with [while a<=b do], and check it in MathCAD or SMath studio program.
I don't need any graphics, I just need to check the function with while loop. You sent example without while loop and without Xlast = 2, so is it possible to check this function with while loop, or no?
#12 Posted : 14 March 2020 16:11:42(UTC)
Pascal is pretty retarded these days for Engineering applications !
Years ago, Mathcad for Universities was pretty freaked.
Better use Smath productive for studies & Engineering.
Golden ratio will be a life time productive Companion.
As well as an advanced WhileLoop.
Golden Ratio jmG.sm (40kb) downloaded 10 time(s).
#13 Posted : 14 March 2020 17:20:50(UTC)
Absolutely, and there are several ways.
If you need a step-by step feedback on the fly you can use breakpoints (menu of math regions) and the debugger window ("View" menu). You might have to store the intermediate results in a dedicated variable though, to don't look into the whole matrix at each step.
Also you can use the function trace() and the output window, or you can build math strings using concat() and other functions, or maybe something more complex using the script region plugin by uni.
loops-1.sm (31kb) downloaded 19 time(s).
Edited by user 14 March 2020 19:40:33(UTC)  | Reason: wrong file attached, whoooops!
thanks 3 users thanked Davide Carpi for this useful post.
on 14/03/2020(UTC),  on 14/03/2020(UTC),  on 17/05/2020(UTC)
Guest (2)
