Hi everyone, I've got problem with while loop. I have this function with Xstart = 0.2 ; Xfinish = 2 ; deltaX = 0.2 and I need to solve it in smath studio, but while loop is processing forever and never ends. I'm doing something wrong, or it's a bug? Thanks! Images: https://postimg.cc/Q9mqWkKd Smath studio https://postimg.cc/KKZkgXPt Function I need to solve Edited by user 14 March 2020 16:35:01(UTC)
| Reason: Not specified
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Is this what you need? Edited by user 13 March 2020 23:01:26(UTC)
Originally Posted by: ndtma Is this what you need? No, I need a range of numbers for X and Y, like: First X = 0.2, it's calculating Y(0.2) and shows first Y result, then X = 0.4 (previous X + delta X) and it's calculating Y(0.4), and until x = 2. In final I need a range of all X and all Y results.
Originally Posted by: Jean Giraud I'm not sure I understood how to solve my function by this examples. I don't know what I'm doing wrong: https://postimg.cc/Q9mqWkKd
Originally Posted by: Yes Man I'm not sure I understood how to solve my function by this examples. Your proposal is not a case of while loop, strictly wrong application. Page44 Unknown.sm (74kb) downloaded 10 time(s).
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
You can do the job using a while loop but it is just one option (perhaps not the most straightforward one). loops.sm (11kb) downloaded 14 time(s).Edited by user 14 March 2020 12:10:02(UTC)
3 users thanked mkraska for this useful post.
on 14/03/2020(UTC), on 14/03/2020(UTC), on 14/03/2020(UTC)
Originally Posted by: Jean Giraud Originally Posted by: Yes Man I'm not sure I understood how to solve my function by this examples. Your proposal is not a case of while loop, strictly wrong application. Page44 Unknown.sm (74kb) downloaded 10 time(s). I need all X and all Y(x) values in the end, for Xfirst = 0.2, Xlast = 2 with step 0.2. y(0.2)= y(0.4)= y(0.6)= ... y(2)= And it should look something like this: x= 0.2 y= -0.6126 x= 0.4 y= 0.2173 x= 0.6 y= 0.7064 x= 0.8 y= 1.0721 x= 1.0 y= 1.3842 x= 1.2 y= 1.6771 x= 1.4 y= 1.9738 x= 1.6 y= 2.2924 x= 1.8 y= 2.6501 x= 2.0 y= 3.0639 I can type every y(x) in smath studio: https://postimg.cc/0bddLTqFBut, is it possible to do it with while loop?
What you are asking for is so restricted and useless for purpose ! Then you can: 1. start wherever [L] as long as computable your ln(,) 2. end wherever [N] 3. as fine step size [Δ] 4. algo style for infinite applications
Originally Posted by: Jean Giraud What you are asking for is so restricted and useless for purpose ! Then you can: 1. start wherever [L] as long as computable your ln(,) 2. end wherever [N] 3. as fine step size [Δ] 4. algo style for infinite applications I'm asking for this cos' we are learning Pascal programming language in university, and we need to write this function in Pascal with [while a<=b do], and check it in MathCAD or SMath studio program. I don't need any graphics, I just need to check the function with while loop. You sent example without while loop and without Xlast = 2, so is it possible to check this function with while loop, or no?
Pascal is pretty retarded these days for Engineering applications ! Years ago, Mathcad for Universities was pretty freaked. Better use Smath productive for studies & Engineering. Golden ratio will be a life time productive Companion. As well as an advanced WhileLoop. Golden Ratio jmG.sm (40kb) downloaded 10 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Originally Posted by: Yes Man so is it possible to check this function with while loop, or no? Absolutely, and there are several ways. If you need a step-by step feedback on the fly you can use breakpoints (menu of math regions) and the debugger window ("View" menu). You might have to store the intermediate results in a dedicated variable though, to don't look into the whole matrix at each step. Also you can use the function trace() and the output window, or you can build math strings using concat() and other functions, or maybe something more complex using the script region plugin by uni. loops-1.sm (31kb) downloaded 19 time(s).Edited by user 14 March 2020 19:40:33(UTC)
| Reason: wrong file attached, whoooops! |
3 users thanked Davide Carpi for this useful post.
on 14/03/2020(UTC), on 14/03/2020(UTC), on 17/05/2020(UTC)
