Firstly thank you for such a wonderful free alternative to MathCad 15. Please see attached .sm file. The comments describe the bug ... Thanks in advance test bug.sm (17kb) downloaded 29 time(s).
Originally Posted by: Jason C Firstly thank you for such a wonderful free alternative to MathCad 15. Please see attached .sm file. The comments describe the bug ... Thanks in advance test bug.sm (17kb) downloaded 29 time(s). Hello, Did not reproduce it... Regards, Radovan |
2 users thanked omorr for this useful post.
on 15/10/2019(UTC), on 15/10/2019(UTC)
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
I could not reproduce either.. |
1 user thanked alyles for this useful post.
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
I could not reproduce either.. Yes, did not reproduce. |
Hmm, I just re-tested on my home PC, freshly booted, same problem. appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference? Edited by user 15 October 2019 19:07:28(UTC)
| Reason: Not specified
Originally Posted by: Jason C Hmm, I just re-tested on my home PC, freshly booted, same problem. appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference? I can confirm this hangs on 7030. I was running 7219 before and did not have an issue. My guess is this should be fixed in next stable release and already seems to be fixed in Beta releases. The question is whether or not the "fix" is intentional or not. |
OK thanks. I will install 7219. Hopefully my Maxima plugin continues to work.
Originally Posted by: Jason C I will install 7219. IMHO, not the best option yet. Who can guess what the angle for loop should be doing ? There are no maths associated with !
Originally Posted by: Jean Giraud Originally Posted by: Jason C I will install 7219. IMHO, not the best option yet. Who can guess what the angle for loop should be doing ? There are no maths associated with ! angle was originally used as such, but I modified it as a troubleshooting step, with no change to the bug's behavior loss := loss + I2ttot(sin(angle*deg)*Ipk)
Originally Posted by: Jason C OK thanks. I will install 7219. Hopefully my Maxima plugin continues to work. It works properly on .7219. But Maxima doesn't work.
Originally Posted by: Jason C But Maxima doesn't work.
What error do you get? Maxima works fine on my end. May need to update the plugin. |
^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030? EDIT: I was able to get Maxima running with .7219. Edited by user 17 October 2019 16:15:03(UTC)
Originally Posted by: Jason C I just re-tested on my home PC, freshly booted, same problem. appVersion(3) = "0.99.7030" not .7219 No matter SS version, by far not a Mathcad clone. Show some Mathcad snippets ... would help doctor the patient. What from Maxima ? Plot, Solve ...
Originally Posted by: Jason C ^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride. |
Originally Posted by: alyles Originally Posted by: Jason C ^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride. I was able to install Maxima with .7219, thank you.
