23 Pages«<1819202122>»
#381 Posted : 12 April 2019 17:23:51(UTC)
Originally Posted by: tomtit Go to Quoted Post
Thanks Jean,
Don't waste your time, I already have solved the problem.
The n supposed to be odd number in the range 3,5,7,9,11. The practical case was 9.
The goal was to derive system of 22 equations. They looked too complicated for doing it manually.
I posted simplest case n=3 just to illustrate the issues I've encountered.
Sorry, I can't go into details, that is a kinda commercial project
OK for pre-selected odd 'n', still wise to generalize Floor style
to avoid crashing the project 'n even' +++ conform to other CAS.
OK commercial copyright ... but unlikely best if not fully doctored.
I understand all that, competitors are reading you in there.
From the 'Floor algo' n=9, n=10 are positive/negative
The looking is tempting to visit the English hat pulse.
Cheers Igor ... Jean
Online uni
#382 Posted : 09 August 2019 18:37:19(UTC)
uni
SMath Studio compatibility mono compatibility Examples
Updated.
Changes:
- MaplePlot refactored;
- now possible to save/load MaplePlot;
- MaplePlot can be used with setprop() function from the X-Y Plot plugin;
- examples added.
plot3d() example plot() example
Edited by user 10 August 2019 11:45:55(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 09/08/2019(UTC),  on 10/08/2019(UTC),  on 11/08/2019(UTC)
Online uni
#383 Posted : 09 August 2019 18:40:08(UTC)
uni
implicitplot3d() example contourplot() example
Edited by user 10 August 2019 11:46:09(UTC)  | Reason: Not specified
Russia ☭ forever
Online uni
#384 Posted : 09 August 2019 18:47:06(UTC)
uni
fieldplot() example polarplot() example
Edited by user 10 August 2019 11:46:21(UTC)  | Reason: Not specified
Russia ☭ forever
Online uni
#385 Posted : 09 August 2019 22:07:05(UTC)
uni
MaplePlot now is not well tested, so you can only test its capabilities. Also I want to remind you that the old computing engine is used. I will try to take the maximum of the available features, but this method will not replace the real components.
Some basic knowledge of how graphic functions work is also needed.
Edited by user 09 August 2019 23:03:12(UTC)  | Reason: Not specified
Russia ☭ forever
Online uni
#386 Posted : 10 August 2019 11:42:09(UTC)
uni
Updated. Maple version changed to 6.
Russia ☭ forever
on 10/08/2019(UTC),  on 10/08/2019(UTC)
Offline Razonar
#387 Posted : 10 August 2019 12:35:27(UTC)
Razonar
Uruguay
Hi. Maybe this could be an alternative for imput long string sequences of options: include them into the description of some varible.
mapletools.plots.sm (13kb) downloaded 39 time(s).
Online uni
#388 Posted : 10 August 2019 12:42:20(UTC)
uni
Yes, this is a very interesting and compact way. I think that you can choose the method you like depending on the task.
It would be great if someone took the time and created a set of templates for different types of charts (maple6.torrent).
Edited by user 14 August 2019 20:44:14(UTC)  | Reason: Not specified
Russia ☭ forever
on 11/08/2019(UTC)
Offline Razonar
#389 Posted : 10 August 2019 13:41:29(UTC)
Razonar
Uruguay
Oh. Tanks very much for the plots, the plugin and the other of your amazing stuff. But ... good bye five. I love it because works on a dosbox emulator with windows for workgroups (3.11 version, 16 bits, but with compatibility library for 32 bits!)
The new features of six version are explained at https://www.maplesoft.co...iew.aspx?path=updates/v6
on 10/08/2019(UTC)
Online uni
#390 Posted : 10 August 2019 14:05:05(UTC)
uni
Maple V Release 5 interpreter
Maple V Release 5 command line interpreter always available as a part of old revisions. You can get it any time if you need.
Also I want to remake the DISLIN plugin in this manner and to embed MS Office apps in SMath worksheet. If anyone has any crazy ideas, then you can tell about them here.
Edited by user 10 August 2019 14:16:40(UTC)  | Reason: Not specified
Russia ☭ forever
Online uni
#391 Posted : 10 August 2019 14:32:03(UTC)
uni
List of available drawing functions. We can use the most part of them.
Russia ☭ forever
Online uni
#392 Posted : 10 August 2019 15:22:24(UTC)
uni
Code:
display(
implicitplot(`in`,
   x={xmn}..{xmx},
   y={ymn}..{ymx},
   axes=normal,
   color=blue,
   labels=[`{xl}`,`{yl}`],
   numpoints={np},
   title=`{tl}`));
Russia ☭ forever
#393 Posted : 10 August 2019 15:54:35(UTC)
Offline ndtma
#394 Posted : 10 August 2019 18:44:10(UTC)
ndtma
Sri Lanka
Was thanked: 125 time(s) in 82 post(s)
With the last update, Mapletools plots do not work.
When trying to insert Maple, I get the following error.
Recent Mapletool plots worked before this update pl.
Mapple Tool Stack Traces.txt (10kb) downloaded 17 time(s).
Online uni
#395 Posted : 10 August 2019 19:34:51(UTC)
uni
Updated. Try now.
Changes:
- Regions.dll updated;
- Debug parameter added to the MapleTools.config file.
Russia ☭ forever
Offline ndtma
#396 Posted : 10 August 2019 20:02:24(UTC)
ndtma
Sri Lanka
Hello Uni
Still does not plot.
Online uni
#397 Posted : 10 August 2019 20:55:42(UTC)
uni
Updated. Again. Try now.
If something wrong then:
- close SMath Studio;
- change Debug parameter to True in MapleTools.config;
- start SMath Studio and repeat again the action;
- show me MapleTools.log.
mapletools.implicitplot.sm (11kb) downloaded 51 time(s).
mapletools.implicitplot.pdf (386kb) downloaded 36 time(s).
Edited by user 11 August 2019 08:20:41(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ndtma
#398 Posted : 11 August 2019 06:36:33(UTC)
ndtma
Sri Lanka
Sorry. Still it does not plot after editing. Before editing did a clean re-installation.
Edited by user 11 August 2019 06:58:54(UTC)  | Reason: Not specified
Online uni
#399 Posted : 11 August 2019 08:16:35(UTC)
uni
Updated.
Show me MapleTools.log. It appears now when SMath Studio works if Debug=True. Near to MapleTools.config. When you try to recalculate worksheet with MaplePlot in log we will see commands or error messages.
Edited by user 11 August 2019 10:04:17(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ndtma
#400 Posted : 11 August 2019 10:49:27(UTC)
ndtma
Sri Lanka
Sorry for my ignorance.
MapleTools_log.txt (2kb) downloaded 31 time(s).
Guest (2)
