Originally Posted by: tomtit Thanks Jean, Don't waste your time, I already have solved the problem. The n supposed to be odd number in the range 3,5,7,9,11. The practical case was 9. The goal was to derive system of 22 equations. They looked too complicated for doing it manually. I posted simplest case n=3 just to illustrate the issues I've encountered. Sorry, I can't go into details, that is a kinda commercial project OK for pre-selected odd 'n', still wise to generalize Floor style to avoid crashing the project 'n even' +++ conform to other CAS. OK commercial copyright ... but unlikely best if not fully doctored. I understand all that, competitors are reading you in there. From the 'Floor algo' n=9, n=10 are positive/negative The looking is tempting to visit the English hat pulse. Cheers Igor ... Jean
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,493 Was thanked: 1274 time(s) in 745 post(s)
Updated. Changes: - MaplePlot refactored; - now possible to save/load MaplePlot; - MaplePlot can be used with setprop() function from the X-Y Plot plugin; - examples added. Edited by user 10 August 2019 11:45:55(UTC)
on 09/08/2019(UTC), on 10/08/2019(UTC), on 11/08/2019(UTC)
⚠ MaplePlot now is not well tested, so you can only test its capabilities. Also I want to remind you that the old computing engine is used. I will try to take the maximum of the available features, but this method will not replace the real components. Some basic knowledge of how graphic functions work is also needed. Edited by user 09 August 2019 23:03:12(UTC)
Updated. Maple version changed to 6. |
on 10/08/2019(UTC), on 10/08/2019(UTC)
Hi. Maybe this could be an alternative for imput long string sequences of options: include them into the description of some varible. mapletools.plots.sm (13kb) downloaded 39 time(s).Best regards. Alvaro.
Yes, this is a very interesting and compact way. I think that you can choose the method you like depending on the task. It would be great if someone took the time and created a set of templates for different types of charts ( maple6.torrent). Edited by user 14 August 2019 20:44:14(UTC)
Originally Posted by: uni Updated. Maple version changed to 6.
Oh. Tanks very much for the plots, the plugin and the other of your amazing stuff. But ... good bye five. I love it because works on a dosbox emulator with windows for workgroups (3.11 version, 16 bits, but with compatibility library for 32 bits!) The new features of six version are explained at https://www.maplesoft.co...iew.aspx?path=updates/v6Best regards. Alvaro.
Maple V Release 5 command line interpreter always available as a part of old revisions. You can get it any time if you need. Quote:Tanks very much for the plots, the plugin and the other of your amazing stuff. Also I want to remake the DISLIN plugin in this manner and to embed MS Office apps in SMath worksheet. If anyone has any crazy ideas, then you can tell about them here. Edited by user 10 August 2019 14:16:40(UTC)
List of available drawing functions. We can use the most part of them.
animate animate3d animatecurve changecoords complexplot complexplot3d conformal contourplot contourplot3d coordplot coordplot3d cylinderplot densityplot display display3d fieldplot fieldplot3d gradplot gradplot3d implicitplot implicitplot3d inequal listcontplot listcontplot3d listdensityplot listplot listplot3d loglogplot logplot matrixplot odeplot pareto pointplot pointplot3d polarplot polygonplot polygonplot3d polyhedra_supported polyhedraplot replot rootlocus semilogplot setoptions setoptions3d spacecurve sparsematrixplot sphereplot surfdata textplot textplot3d tubeplot
Code:display(
implicitplot(`in`,
x={xmn}..{xmx},
y={ymn}..{ymx},
axes=normal,
color=blue,
labels=[`{xl}`,`{yl}`],
numpoints={np},
title=`{tl}`));
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 124 time(s) in 82 post(s)
With the last update, Mapletools plots do not work. When trying to insert Maple, I get the following error. Recent Mapletool plots worked before this update pl. Mapple Tool Stack Traces.txt (10kb) downloaded 17 time(s). |
Updated. Try now.
Changes:
- Regions.dll updated; - Debug parameter added to the MapleTools.config file. |
Hello Uni Still does not plot. |
Updated. Again. Try now. If something wrong then: - close SMath Studio; - change Debug parameter to True in MapleTools.config; - start SMath Studio and repeat again the action; - show me MapleTools.log. mapletools.implicitplot.sm (11kb) downloaded 51 time(s). mapletools.implicitplot.pdf (386kb) downloaded 36 time(s).Edited by user 11 August 2019 08:20:41(UTC)
Sorry. Still it does not plot after editing. Before editing did a clean re-installation. Edited by user 11 August 2019 06:58:54(UTC)
Updated. Show me MapleTools.log. It appears now when SMath Studio works if Debug=True. Near to MapleTools.config. When you try to recalculate worksheet with MaplePlot in log we will see commands or error messages. Edited by user 11 August 2019 10:04:17(UTC)
