Offline Stefan Weisskircher
#1 Posted : 23 July 2019 15:59:53(UTC)
Stefan Weisskircher
I have a simple integral calculation which contains a varable "n". If this variable is calculated in an earlier step, a wrong result is returned; the same calculation with a defined value for the variable (called "n2" in the example), the correct result appears. SMath Studio version 0.99, build 7030.
Is there a possibility to upload my sample file?
Edited by user 23 July 2019 16:03:04(UTC)  | Reason: Not specified
Offline alyles
#2 Posted : 23 July 2019 16:04:05(UTC)
alyles
What version are you running?
I'm not seeing this issue on 7109.
Might help if you also posted the .sm file in question.
#3 Posted : 23 July 2019 16:07:13(UTC)
Stefan Weisskircher
Hello alyles,
thanks for your answer! I have already edited my original post to add the version info.
i cannot find a button to upload my sample file... Sad (still searching)
Edited by user 23 July 2019 16:09:16(UTC)  | Reason: Not specified
Offline alyles
#4 Posted : 23 July 2019 16:07:18(UTC)
alyles
Sorry I missed this. To upload start writing a comment, click the following button....
then click add file first. Navigate to file and select. Then you must click start upload to upload it.
#5 Posted : 23 July 2019 16:11:11(UTC)
Stefan Weisskircher
Thanks again, here we go:
Bug_Integral.sm (5kb) downloaded 16 time(s).
Offline alyles
#6 Posted : 23 July 2019 16:12:41(UTC)
alyles
Are you concerned with the fractional result on the red?
If so right click on that section and change optimization to numeric. You'll get a numeric result.
#7 Posted : 23 July 2019 16:16:05(UTC)
Stefan Weisskircher
Doesn't help, I still get "-18" in the left section (which isn't correct IMHO and still deiffers from the result on the right side (green))
Offline alyles
#8 Posted : 23 July 2019 16:20:00(UTC)
alyles
Ok I just tried this in 7030 (latest stable) and can confirm I get the same results as you. This looks like a bug.
when I performed the same calculation in the newest beta version, the results seem correct.
Edited by user 23 July 2019 16:21:47(UTC)  | Reason: Not specified
#9 Posted : 23 July 2019 16:20:00(UTC)
Stefan Weisskircher
Thanks a lot! So I don't have to search anymore! Clap
Edited by user 23 July 2019 16:23:20(UTC)  | Reason: Not specified
#10 Posted : 24 July 2019 17:58:21(UTC)
Always plot the integrand for reluctant region.
Doctored SS 6179 ... seemingly same as SS7109
Bug_Integral [Doctored].sm (24kb) downloaded 17 time(s).
Guest (2)
