SMath Studio Forum
Bugs & Problems
Error integrating with interim result
Joined: 23/07/2019(UTC) Posts: 7 Location: Saarbrücken
I have a simple integral calculation which contains a varable "n". If this variable is calculated in an earlier step, a wrong result is returned; the same calculation with a defined value for the variable (called "n2" in the example), the correct result appears. SMath Studio version 0.99, build 7030. Is there a possibility to upload my sample file? Edited by user 23 July 2019 16:03:04(UTC)
| Reason: Not specified
What version are you running?
I'm not seeing this issue on 7109.
Might help if you also posted the .sm file in question. |
Hello alyles, thanks for your answer! I have already edited my original post to add the version info. i cannot find a button to upload my sample file... (still searching) Edited by user 23 July 2019 16:09:16(UTC)
Sorry I missed this. To upload start writing a comment, click the following button.... then click add file first. Navigate to file and select. Then you must click start upload to upload it. |
Are you concerned with the fractional result on the red?
If so right click on that section and change optimization to numeric. You'll get a numeric result. |
Doesn't help, I still get "-18" in the left section (which isn't correct IMHO and still deiffers from the result on the right side (green))
Ok I just tried this in 7030 (latest stable) and can confirm I get the same results as you. This looks like a bug. when I performed the same calculation in the newest beta version, the results seem correct. Edited by user 23 July 2019 16:21:47(UTC)
Thanks a lot! So I don't have to search anymore! Edited by user 23 July 2019 16:23:20(UTC)
Originally Posted by: Stefan Weisskircher Thanks a lot! So I don't have to search anymore! Always plot the integrand for reluctant region. Doctored SS 6179 ... seemingly same as SS7109 Bug_Integral [Doctored].sm (24kb) downloaded 17 time(s).
SMath Studio Forum
Bugs & Problems
