Joined: 20/03/2019(UTC) Posts: 73 Location: Mandeville, LA
I am trying to type this formula:
De=1.3*[[(H*W)^0.625]/(H+W)^0.25] But SMath is refusing to put the parentheses in the correct places.
This is what SMath wants to type:
D.e:1.3*{(H)*W^0.625}/{(H+W)^0.25}, and the answer is 15.98 but with the paranthises in the correct places the answer is 10.93. Does not want to multiple the top numbers together before taking the number to the 0.625 power. It wants to multiply the first number by the second number taken to the 0.625 power instead.
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
Originally Posted by: Britt1 This is what SMath wants to type:
D.e:1.3*{(H)*W^0.625}/{(H+W)^0.25}, and the answer is 15.98 but with the paranthises in the correct places the answer is 10.93. Does not want to multiple the top numbers together before taking the number to the 0.625 power. It wants to multiply the first number by the second number taken to the 0.625 power instead. Try typing this directly. Note that -> signifies the right arrow on the keyboard. D.e:1.3*(H*W->->^0.625->/(H+W->->^0.25= |
Originally Posted by: Britt1 I am trying to type this formula:
De=1.3*[[(H*W)^0.625]/(H W)^0.25] But SMath is refusing to put the parentheses in the correct places.
How do I type the [H:=X.X W:=X.XX]? if I type the [, I get the square boxes for math inputs. I Get 2 in a diagonal format. I can't figure out how to type [ in SMath. This will be very useful format for what I am doing.
That is a Matrix. Try Ctrl+M 1,2 to create a 1x2 matrix. Then fill appropriately. |
Originally Posted by: alyles That is a Matrix. Try Ctrl+M 1,2 to create a 1x2 matrix. Then fill appropriately. Thank you.
Originally Posted by: Britt1 I can't figure out how to type [ in SMath. ... from the keyboard.
Originally Posted by: Britt1 I can't figure out how to type [ in SMath. ... like this also.
Thank you. That really helps in what I am doing.
