#1 Posted : 11 April 2019 16:21:35(UTC)
Can't make it work ... SS 6179
Please, can you quick verdict: NOT compatible
or if possible doctor the patient ?
It may have to be constructed recursive style
Thanks in advance ... Jean
Spline Bspline FAILS.sm (67kb) downloaded 18 time(s).
Offline alyles
#2 Posted : 11 April 2019 18:57:17(UTC)
alyles
Here's something that at least evaluates on 0.99.7030. One thing to note about your function.
There isn't a "return" statement in Smath programming. A program returns the last line entry by default. So to compensate, you have to assign values to a variable and pass that variable at the end. In this case I chose "ans".
I also used "cases" function to clean things up a bit.
Spline Bspline PASSES-alyles.sm (69kb) downloaded 15 time(s).
Offline alyles
#3 Posted : 11 April 2019 19:36:28(UTC)
alyles
I had an error some of the logic. Also updated to mimic graph that was attached.
Spline Bspline PASSES-alyles.sm (80kb) downloaded 13 time(s).
Spline Bspline PASSES-alyles.pdf (267kb) downloaded 17 time(s).
#4 Posted : 11 April 2019 20:28:15(UTC)
Thanks Grand Doctor Alyles ... works fine.
Will refresh soon ... Jean
