Can't make it work ... SS 6179 Please, can you quick verdict: NOT compatible or if possible doctor the patient ? It may have to be constructed recursive style Thanks in advance ... Jean Spline Bspline FAILS.sm (67kb) downloaded 18 time(s).
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
Originally Posted by: Jean Giraud Can't make it work ... SS 6179 Please, can you quick verdict: NOT compatible or if possible doctor the patient ? It may have to be constructed recursive style
Here's something that at least evaluates on 0.99.7030. One thing to note about your function. There isn't a "return" statement in Smath programming. A program returns the last line entry by default. So to compensate, you have to assign values to a variable and pass that variable at the end. In this case I chose "ans". I also used "cases" function to clean things up a bit. Spline Bspline PASSES-alyles.sm (69kb) downloaded 15 time(s). |
Originally Posted by: alyles Here's something that at least evaluates on 0.99.7030. One thing to note about your function. There isn't a "return" statement in Smath programming. A program returns the last line entry by default. So to compensate, you have to assign values to a variable and pass that variable at the end. In this case I chose "ans". Thanks Grand Doctor Alyles ... works fine. Will refresh soon ... Jean
