SMath Studio Forum
Bugs & Problems
Error Highlight not picking up the right 'error'
Originally Posted by: CBG This is an approach, maybe Jean or Alvaro, can Doctor it Hello Carlos, maybe like this ... solve(2) to let the solver breath freely. Cheers ... Jean PileRedux_Factor_CBG [1].sm (25kb) downloaded 23 time(s).
Joined: 23/03/2016(UTC) Posts: 277 Was thanked: 91 time(s) in 57 post(s)
Hi Jean, See attached. I've modified your strip2() algorithm [See Strip3()]. On my PC it performs same calculations ~10x faster. Might help with large data sets. PileRedux_Factor_CBG [1]_alyles.sm (32kb) downloaded 26 time(s). |
Originally Posted by: alyles Might help with large data sets.
Here's some proof of that. |
Originally Posted by: alyles Hi Jean,
See attached. I've modified your strip2() algorithm [See Strip3()]. On my PC it performs same calculations ~10x faster. Might help with large data sets. Thanks alyles ... Good job !
Originally Posted by: Razonar Hola Alvaro. Gracias I make the next comment. In none of the 3 graphs that you show, the scale of the "Y" axis, reaches the value 10, so I think, it would be necessary to expand the scale to verify that the curves are correct Best Regards Carlos
Originally Posted by: Jean Giraud Hello Carlos, maybe like this ... solve(2) to let the solver breath freely. Cheers ... Jean PileRedux_Factor_CBG [1].sm (25kb) downloaded 23 time(s). Hello Jean Thank you so much . Very pretty Best Regards Carlos
Originally Posted by: CBG I make the next comment. In none of the 3 graphs that you show, the scale of the "Y" axis, reaches the value 10, so I think, it would be necessary to expand the scale to verify that the curves are correct Carlos, the limits are the limits of the solver. I refactored a bit to understand myself easier, played a bit the lower limits [A5, A6] ... bingo ! That reminds me how long it toke Mathcad 11 to solve the Solar Cell project ... let say ~ 1 month. Cheers ... Jean Page4 Carlos.sm (30kb) downloaded 15 time(s).
Originally Posted by: CBG Hello Jean
Thank you so much. Very pretty. Best Regards. Carlos Hola Carlos, Few more things to improve presentation ... Decimate part of the A1, A2,A3 . Confirm project is valid particularly withe 'z' target in A solvers. Project PileRedux_Factor_CBG [1].sm (31kb) downloaded 18 time(s).
Originally Posted by: CBG ... I make the next comment. In none of the 3 graphs that you show, the scale of the "Y" axis, reaches the value 10, so I think, it would be necessary to expand the scale to verify that the curves are correct
Hola Carlos. Maxima shows 10 for both axis, IPlotSolve, by construction, only can take two vectors (x or y and lambda) but not 3 (x and y and lambda). For pIPlot and pVField, just change the Box in 'B'. I take columns only one to five. Best regards. Alvaro.
Originally Posted by: Jean Giraud Hola Carlos, Few more things to improve presentation ... ... decimated plots are lot more presentable. At this point, for a specific target solution easy to get a Thiele analytical formulation. In the mean time, I will test some decay model. Cheers ... Jean Project PileRedux_Factor_CBG [1].sm (47kb) downloaded 16 time(s).
SMath Studio Forum
Bugs & Problems
