2 Pages<12
Offline Razonar
#21 Posted : 28 March 2019 10:08:23(UTC)
Razonar
Uruguay
Hola Carlos. This is another approach.
PileRedux_Factor_CBG.sm (116kb) downloaded 23 time(s).
PileRedux_Factor_CBG.pdf (377kb) downloaded 17 time(s).
#22 Posted : 28 March 2019 16:00:16(UTC)
Originally Posted by: CBG Go to Quoted Post
This is an approach, maybe Jean or Alvaro, can Doctor it
Hello Carlos, maybe like this ... solve(2) to let the solver breath freely.
PileRedux_Factor_CBG [1].sm (25kb) downloaded 23 time(s).
on 28/03/2019(UTC)
Offline alyles
#23 Posted : 28 March 2019 16:56:11(UTC)
alyles
Hi Jean,
See attached. I've modified your strip2() algorithm [See Strip3()]. On my PC it performs same calculations ~10x faster. Might help with large data sets.
PileRedux_Factor_CBG [1]_alyles.sm (32kb) downloaded 26 time(s).
Offline alyles
#24 Posted : 28 March 2019 18:37:37(UTC)
alyles
Here's some proof of that.
#25 Posted : 28 March 2019 19:24:24(UTC)
Hi Jean,
Thanks alyles ... Good job !
Offline CBG
#26 Posted : 28 March 2019 19:37:05(UTC)
CBG
Hola Alvaro.
Gracias
I make the next comment. In none of the 3 graphs that you show,
the scale of the "Y" axis, reaches the value 10, so I think,
it would be necessary to expand the scale to verify that the curves are correct
Carlos
Offline CBG
#27 Posted : 28 March 2019 19:41:53(UTC)
CBG
Hello Jean
Thank you so much .
Very pretty
Carlos
#28 Posted : 28 March 2019 21:17:41(UTC)
Carlos, the limits are the limits of the solver.
I refactored a bit to understand myself easier,
played a bit the lower limits [A5, A6] ... bingo !
That reminds me how long it toke Mathcad 11 to solve
the Solar Cell project ... let say ~ 1 month.
Page4 Carlos.sm (30kb) downloaded 15 time(s).
#29 Posted : 29 March 2019 04:29:22(UTC)
Hello Jean
Thank you so much. Very pretty. Best Regards. Carlos
Hola Carlos,
Few more things to improve presentation ...
Decimate part of the A1, A2,A3 . Confirm project is valid
particularly withe 'z' target in A solvers.
Project PileRedux_Factor_CBG [1].sm (31kb) downloaded 18 time(s).
Offline Razonar
#30 Posted : 29 March 2019 04:42:38(UTC)
Razonar
Uruguay
... I make the next comment. In none of the 3 graphs that you show,
Hola Carlos. Maxima shows 10 for both axis, IPlotSolve, by construction, only can take two vectors (x or y and lambda) but not 3 (x and y and lambda).
For pIPlot and pVField, just change the Box in 'B'. I take columns only one to five.
#31 Posted : 29 March 2019 15:45:43(UTC)
Hola Carlos,
... decimated plots are lot more presentable.
At this point, for a specific target solution
easy to get a Thiele analytical formulation.
In the mean time, I will test some decay model.
Project PileRedux_Factor_CBG [1].sm (47kb) downloaded 16 time(s).
#32 Posted : 29 March 2019 18:42:43(UTC)
... a pretty good fit. More models to be explored.
Project PileRedux_Factor_CBG [1] Rational Fit.sm (59kb) downloaded 14 time(s).
#33 Posted : 29 March 2019 23:40:28(UTC)
... patience is rewarded, an exact fit
considering the inexact solver solutions.
Project PileRedux_Factor_CBG [1] Exact Homographic.sm (51kb) downloaded 16 time(s).
2 Pages<12
