Offline conrad
#1 Posted : 07 February 2019 16:08:26(UTC)
conrad
I have the following problem, trying to solve the definite integral int((3*x^3-x^2+2*x-4)/sqrt(x^2-3*x+2),dx,0,1): I get the error "x - not defined" and, of course, no result.
If I change the limits to [0..401], I get a result (!) with no error message, but if I set the upper limit lower than 401, I get the error again...
What is the reason for that?
Thanks in advance for your replies.
Conrad
#2 Posted : 07 February 2019 17:13:06(UTC)
The integrand is undefined @ x = 1
#3 Posted : 07 February 2019 17:41:17(UTC)
Three verdicts in there:
1. Nothing will integrate that freak above x=1.9999999999999999999999999999
2. Nothing will integrate up to x=0.99999999999999999999999999999999
3. Can only integrate in reasonable range of the integrand.
Interesting Classroom example ... always plot the integrand !!!
IntegrateFreak.sm (8kb) downloaded 40 time(s).
#4 Posted : 07 February 2019 18:32:46(UTC)
Hello Conrad,
Often, it is possible to improve the Smath native Simpson integrator.
Romberg is profitable in example 2 which looks easy from plotting
the integrand, but finally is not so.
Integrate Romberg Technical.sm (52kb) downloaded 44 time(s).
Offline overlord
#5 Posted : 08 February 2019 09:50:36(UTC)
Turkey
you can use maxima plugin if it is necessary.
Offline Razonar
#6 Posted : 08 February 2019 12:33:47(UTC)
Razonar
Uruguay
Hi. I think that here the point is how to handle avoidable discontinuities in SMath. Because integral and other operators or functions not accept the 'if' statement, you can use 'cases' in the definition of f, as this:
Even this isn't the case, this other is more general for avoiding numerical issues with avoidable discontinuities:
on 08/02/2019(UTC)
Offline Razonar
#7 Posted : 08 February 2019 12:47:42(UTC)
Razonar
Uruguay
About the other discontinuity, at x=2, I guess that you don't want to work with complexes. It's usual take the absolute vale of logs and roots in real analysis calculus. This other isn't avoidable discont, but can be handled in a similar way.
discont_integral.sm (9kb) downloaded 41 time(s).
thanks 3 users thanked Razonar for this useful post.
on 08/02/2019(UTC),  on 08/02/2019(UTC),  on 08/02/2019(UTC)
Offline uni
#8 Posted : 08 February 2019 14:33:05(UTC)
uni
maple() also can do that.
Edited by user 08 February 2019 14:38:33(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
#9 Posted : 08 February 2019 19:34:33(UTC)
maple [0..1] = -2.98126694400594
Mathcad 11 [0..1]= -2.98126694400554
Smath = -2.98126668567898 ... acc 10000
This is a case of singular end point
Offline Razonar
#10 Posted : 08 February 2019 21:16:38(UTC)
Razonar
Uruguay
Originally Posted by: Razonar Go to Quoted Post
... This other isn't avoidable discont, but can be handled in a similar way.
Well, actually, the integral converges for x=2, as one can see in this wolfram result
That's means that numerical procedure for computing int in SMath needs some improvements.
#11 Posted : 08 February 2019 22:13:59(UTC)
That's an old long due request.
At least, we have the adaptive from Carlos
Romberg algo style works well, very useful too.
Guest (2)
