SMath Studio Forum
Questions
Definite integral - "x - not defined" ?
I have the following problem, trying to solve the definite integral int((3*x^3-x^2+2*x-4)/sqrt(x^2-3*x+2),dx,0,1): I get the error "x - not defined" and, of course, no result. If I change the limits to [0..401], I get a result (!) with no error message, but if I set the upper limit lower than 401, I get the error again... What is the reason for that? Thanks in advance for your replies.
Conrad
Originally Posted by: conrad If I change the limits to [0..401] The integrand is undefined @ x = 1
Originally Posted by: Jean Giraud The integrand is undefined @ x = 1 Three verdicts in there: 1. Nothing will integrate that freak above x=1.9999999999999999999999999999 2. Nothing will integrate up to x=0.99999999999999999999999999999999 3. Can only integrate in reasonable range of the integrand. Interesting Classroom example ... always plot the integrand !!! IntegrateFreak.sm (8kb) downloaded 40 time(s).
Hello Conrad, Often, it is possible to improve the Smath native Simpson integrator. Romberg is profitable in example 2 which looks easy from plotting the integrand, but finally is not so. Jean Integrate Romberg Technical.sm (52kb) downloaded 44 time(s).
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 508 time(s) in 338 post(s)
you can use maxima plugin if it is necessary. Regards
Hi. I think that here the point is how to handle avoidable discontinuities in SMath. Because integral and other operators or functions not accept the 'if' statement, you can use 'cases' in the definition of f, as this: Even this isn't the case, this other is more general for avoiding numerical issues with avoidable discontinuities: Best regards. Alvaro.
About the other discontinuity, at x=2, I guess that you don't want to work with complexes. It's usual take the absolute vale of logs and roots in real analysis calculus. This other isn't avoidable discont, but can be handled in a similar way. discont_integral.sm (9kb) downloaded 41 time(s).Best regards. Alvaro.
3 users thanked Razonar for this useful post.
on 08/02/2019(UTC), on 08/02/2019(UTC), on 08/02/2019(UTC)
maple() also can do that. Edited by user 08 February 2019 14:38:33(UTC)
Originally Posted by: uni maple() also can do that.
maple [0..1] = -2.98126694400594 Mathcad 11 [0..1]= -2.98126694400554 Smath = -2.98126668567898 ... acc 10000 This is a case of singular end point
Originally Posted by: Razonar ... This other isn't avoidable discont, but can be handled in a similar way.
Well, actually, the integral converges for x=2, as one can see in this wolfram result That's means that numerical procedure for computing int in SMath needs some improvements. Best regards. Alvaro.
Originally Posted by: Razonar That's means that numerical procedure for computing int in SMath needs some improvements. That's an old long due request. At least, we have the adaptive from Carlos Romberg algo style works well, very useful too.
SMath Studio Forum
Questions
