Offline Ber7
#1 Posted : 27 January 2019 14:36:20(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
#2 Posted : 27 January 2019 16:28:50(UTC)
"In version 0.99.6884, membrane animations do not work."
What do you mean: all those linked Bessel animations don't work [1 year old]
from the Smath Matlab library mwbesselj(N,x) ? Is that so ?
Does it mean part or all mwXXX library 6884 is zap ?
That would a damned bug. All my Fourier documents would be red by switching 6179 => 6884
Offline uni
#3 Posted : 27 January 2019 16:38:17(UTC)
uni
Matlab functions work only for 32-bit version of SMath Studio. You can use Cephes Math Library.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Ber7
#4 Posted : 27 January 2019 18:44:11(UTC)
Ber7
Israel
"What do you mean: all those linked Bessel animations don't work [1 year old]
from the Smath Matlab library mwbesselj(N,x) ? Is that so ?"
Uni, the problem with the Bessel function is not related. The problem is in
the F (u, v) function that CreateMesh uses.Look at the attached file
https://en.smath.com/forum/resource.ashx?a=15089&b=2
In the function F (u, v) for animation, I used not two, but four arguments F (u, v, t, delta).
The problem is that the latest version does not allow increasing the number of arguments above two.
#5 Posted : 27 January 2019 18:51:32(UTC)
OK, it concerns the very latest version, Thanks
Offline uni
#6 Posted : 27 January 2019 18:57:54(UTC)
uni
Plugin updated. Try now.
Edited by moderator 03 February 2019 14:14:05(UTC)  | Reason: marked as Solved
Russia ☭ forever
Offline loha
#7 Posted : 28 January 2019 08:10:23(UTC)
loha
Was thanked: 9 time(s) in 9 post(s)
The membrane sheet does not work online also!
#8 Posted : 28 January 2019 22:29:23(UTC)
Originally Posted by: loha Go to Quoted Post
The membrane sheet does not work online also !
Update as advised by Viacheslav.
What do you mean does not evaluate on-line ?
It evaluates the work sheet.
Guest (2)
