SMath Studio Forum
Bugs & Problems
In version 0.99.6884, membrane animations do not work.
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
"In version 0.99.6884, membrane animations do not work." What do you mean: all those linked Bessel animations don't work [1 year old] from the Smath Matlab library mwbesselj(N,x) ? Is that so ? Does it mean part or all mwXXX library 6884 is zap ? That would a damned bug. All my Fourier documents would be red by switching 6179 => 6884
Matlab functions work only for 32-bit version of SMath Studio. You can use Cephes Math Library. |
"What do you mean: all those linked Bessel animations don't work [1 year old] from the Smath Matlab library mwbesselj(N,x) ? Is that so ?" Uni, the problem with the Bessel function is not related. The problem is in the F (u, v) function that CreateMesh uses.Look at the attached file https://en.smath.com/forum/resource.ashx?a=15089&b=2In the function F (u, v) for animation, I used not two, but four arguments F (u, v, t, delta). The problem is that the latest version does not allow increasing the number of arguments above two.
Originally Posted by: Ber7 In the function F (u, v) for animation, I used not two, but four arguments F (u, v, t, delta). The problem is that the latest version does not allow increasing the number of arguments above two. OK, it concerns the very latest version, Thanks
Originally Posted by: Ber7 In the function F (u, v) for animation, I used not two, but four arguments F (u, v, t, delta). The problem is that the latest version does not allow increasing the number of arguments above two. Plugin updated. Try now. Edited by moderator 03 February 2019 14:14:05(UTC)
| Reason: marked as Solved |
Was thanked: 9 time(s) in 9 post(s)
The membrane sheet does not work online also!
Originally Posted by: loha The membrane sheet does not work online also ! Update as advised by Viacheslav. What do you mean does not evaluate on-line ?It evaluates the work sheet.
SMath Studio Forum
Bugs & Problems
