Offline alfanancy
#1 Posted : 26 October 2018 09:26:10(UTC)
alfanancy
Indonesia
Hi All,
I have created an equation and with range function. as picture attached :
2018-10-26 11_40_59-SMath Studio - [Power Cable Ampacity Calculations IEC 60287&Cigre B1-03.sm_].png
on function of (psoil), i have an error notification that cannot calculate.
but if using matcad, i have result as :
please advise how to get the result same as mathcad ?
thanks in advance
best regards
aditia
Offline Razonar
#2 Posted : 26 October 2018 09:30:44(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi aditia. Without the worksheet can't be sure, but guess that you can try to vectorize the evaluation: in the same cursor position in the picture, press the vectorize button from the matrix palette.
Offline alfanancy
#3 Posted : 26 October 2018 12:21:06(UTC)
alfanancy
Indonesia
Hi Alvaro,
i try to vectorize as per your suggestion, and the result it work. thankyou a lot for your solution.
Edited by moderator 26 October 2018 15:19:51(UTC)  | Reason: marked as solved
#4 Posted : 26 October 2018 18:14:47(UTC)
that fails to calculate
As it looks: quite simple if all components in the main equation are defined
vectorize the result because you have 'soil' in vector format.
Vectorize operator from the palette.
