SMath Studio Forum
Questions
range calculation "Cannot calculate" error
Hi All, I have created an equation and with range function. as picture attached : on function of (psoil), i have an error notification that cannot calculate. but if using matcad, i have result as : please advise how to get the result same as mathcad ? thanks in advance best regards aditia
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Hi aditia. Without the worksheet can't be sure, but guess that you can try to vectorize the evaluation: in the same cursor position in the picture, press the vectorize button from the matrix palette.
Best regards. Alvaro.
Hi Alvaro, i try to vectorize as per your suggestion, and the result it work. thankyou a lot for your solution. Edited by moderator 26 October 2018 15:19:51(UTC)
| Reason: marked as solved
Originally Posted by: alfanancy I have created an equation and with range function. that fails to calculate As it looks: quite simple if all components in the main equation are defined vectorize the result because you have 'soil' in vector format. Vectorize operator from the palette. Cheers ... Jean
SMath Studio Forum
Questions
